How to use extrim command in autolisp
Message 1 of 8
I want use extrim command in my lisp program. But, autolisp not recognizing the command. Can anyone suggest how to use it?
Replies (7)
Message 2 of 8
marko_ribar
Analyze last 2 codes posted here :
http://www.cadtutor.net/forum/showthread.php?93620-Explode-Blocks-Then-Trim-Rectangle-amp-Circle-Ins...
- you call extrim with (etrim ename pt), but be aware that your highlight sysvar will be reset to 0, so return it back afterwards to 1...
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 8
Thanks for the reply. I'll try this.
Message 4 of 8
phanaem
Try
(if
  (cond
    (etrim)
    (T (load "extrim.lsp" "") etrim)
  (etrim <ename> <point>)
where <ename> is the ename of the cutting object and <point> define the cutting side
Message 5 of 8
saifumk8
the link is not working it's showing:
"The page you requested does not exist"
Message 6 of 8
saifumk8
all express tools lisp code is available in below link:
C:\Program Files\Autodesk\AutoCAD 2015\Express
Message 7 of 8
saifumk8
thanks
Message 8 of 8
saifumk8
thank you very much it's working with below code:
(setq ent1 (entsel))
(setq pt1 (getpoint))
(if
(cond
(etrim)
(etrim (car ent1) pt1)
