How to use extrim by pyautocad?
01131042
01131042
I wanted to use extrim command by this sample of code:
command = "extrim "
doc.SendCommand(command)
Then, user have to pick a polygon by hand. I want to provide there an object predefined in code. Is there an option to pass an object into command instead of picking manually?
john.uhden
@01131042 ,
This area of the forum is for Autolisp/Visual Lisp customization.
Your snippet doesn't look like Autolisp.
If it were Autolisp you could use the vlax-add-cmd function to make an AutoCad command of it without having to modify the code, e.g.
(defun tires ( / #)
  (setq # (getint "\nHow many tires are on the vehicle?:  "))
  (princ (strcat "\nThere are " (itoa #) " tires on the vehicle."))
  (princ)
(vlax-add-cmd "tires" 'tires)
which allows you to feed the # from the command line, e.g.
(command "tires" 4)
John F. Uhden
Sea-Haven
Have a look inside Extrim.lsp and you will see a defun (Etrim, so if you (load "Extrim") you can call the use of it by (Etrim ent pt), hopefully you understand.
daniel_cadext
AutoLISP and General Customization forum
Lisp doesn’t have a SendCommand? (vla-sendcommand)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
