how to use ade_odgetfield?
dwattersAMXH5
dwattersAMXH5
hello,
i am wanting to use ADE_ODGETFIELD to save object data to a list of variables but i am finding very little documentation explaining how to actually use it, how do i point it to the correct OD table?
in more detail what i want to do is
  • select a line
  • run command
    • get an object data field for that line (field is "FQN_ID") and save the field as a variable
      *in full transparency i really need to build this in a foreach that way if multiple lines are selected (they would be on top of each other but have different "FQN_ID" fields) it will get the field from both (all?) lines and build a list that i can then call with a variable
    • create multi-leader
      • pause for start and end points
      • call in variable to populate text
 any help i can get on understanding how to use ADE_ODGETFIELD and store it to a variable would be greatly appreciated
thanks.
dwattersAMXH5
(defun c:mlfq (/)
(setq ent (car (entsel "\nSelect line")))
(setq lst (ade_odgettables ent))
(setq fqnid (ade_odgetfield ent lst "FQN_ID" O))
(command "mleader" pause pause fqnid)
i've gotten here in testing but the leader is coming back blank (no text where var fqnid should be supplying the information out of the od field)
dwattersAMXH5
(defun c:mlfq (/)
  (princ "\nSelect SOURCE object: ")
  (setq source_obj (car (entsel)))
  (if (null source_obj)
    (prompt "\nNo source object selected.")
    (progn
      (setq lst (ade_odgettables source_obj))
      (setq fqnid (ade_odgetfield source_obj lst "FQN_ID" O))
or  this - to catch if the object isn't being grabbed. still not getting object data across to leader
CodeDing
@dwattersAMXH5,
It's not perfect, but this should get you on the right track!
Best,
~DD
(defun c:mlfq ( / ss e tbl tmp fqnid)
;prompt before ssget because you cannot add prompt within ssget
(prompt "\nSelect Entities with Object Data: \n")
;if selection set (ss) has objects
(if (setq ss (ssget))
(progn
  	;temporary counting variable
  	(setq tmp 0)
  	;repeat for number of objects in ss
	(repeat (sslength ss)
	  	;get entity name from position in ss (tmp is position)
		(setq e (ssname ss tmp))
	  	;get first table in OD
	  	(setq tbl (car (ade_odgettables e)))
	  	;check if field returns a value, store as variable
	  	(if (setq fqnid (ade_odgetfield e tbl "FQN_ID" 0))
		(progn
		  	;zoom to entity for easy multileader insertion
			(command "zoom" "o" e "")
		  	;add mleader that user will insert, provide default text
		  	(command "_.mleader" pause pause fqnid)
		));progn/if
	  	;increment temporary count
	  	(setq tmp (1+ tmp))
	);repeat
);progn
;else
;let user know if nothing selected
(prompt "\nNothing Selected.")
);if
(princ);finish quietly
);defun
dwattersAMXH5
thank you!
also i found my problem with my code being a miss-type at
O not being 0 (zero) (what can i say - still getting used to a new keyboard lol)
