How to UnCheck the option of 'display layout background' by lisp?
swaywood
swaywood
usualy we done this by the option/display/layout element/the toogle option 'display layout background'
now i want to set it by lisp, is there any system value to set this? or some other method to check it.
dbroad
;;to get the display preferences object
(setq dpref (vla-get-display
	      (vla-get-preferences
		(vlax-get-acad-object)))
;;to get the current setting of the paper space background
(vla-get-layoutdisplaypaper dpref)
;;to turn the background on
(vla-put-layoutdisplaypaper dpref :vlax-true)
;;to turn the background off
(vla-put-layoutdisplaypaper dpref :vlax-false)
;;to update the layout display
(vla-regen (vla-get-activedocument
  acAllViewports)
Architect, Registered NC, VA, SC, & GA.
m_badran
There is no system value, but you can do it with lisp.
(vl-load-com)
(setq acadObj (vlax-get-acad-object))
(setq preferences (vla-get-Preferences acadObj))
(vla-put-LayoutDisplayPaper (vla-get-Display preferences) :vlax-true);you can change to false
(setq thisdrawing
(vla-Regen thisdrawing acAllViewports)
