How to stop load rountine from Bundle after first loading
majklha
majklha
I have LSP in bundle directory. After run acad this "bundle" lisp make some initialization settings in current profile/current run autocad. Next way  my application will be started during menu file (mnl file). In this time I want to stop reading bundle for this version of acad. Is for this some method?
Thanks for help.
Scottu2
Hello Majklha,
Maybe try to change the way the Bundle lips operates.
Option 1: Add the question "Run Bundle routines now <No>: "
Option 2: Add file date and time comparison between two files.
For example, if your routine loads and .MNU then AutoCAD creates new a .mnl.
The Bundle routine should first get the current date and time for the .mnu and .mnl files.
If the .mnl file has a later date and time than the .mnu file then exit the routine, otherwise continue to running the routine.
majklha
