How to simulate a Key beeing pressed in a LISP Routine?
alx86
alx86
I'm trying to create a very basic LISP routine that will:
-change to next Layout Tab
-Lock all viewport
-Zoom/Extent
the only part I don't know how to do, is to simulate ctrl+pagedown being pressed to change tab
My LISP look like this so far:
(defun C:NE (/)
  (ctrl+pagedown) <---- How should I write this part?
  (command "_.PSPACE" "mview" "l" "on" "all" "")
  (command "ZOOM" "E")
Thanks for any help 🙂
M_Hensley
To change layouts in lisp you need to know the layout name. To switch to layout1 would be (setvar "ctab" "layout1")
(layoutlist) will return a list of layouts so you can do so comparative tests.
hmsilva
-Lock all viewport
-Zoom/Extent
Hi abonneau,
The 'layoutlist' function will return a list with all layouts in alphabetical order, not in tab order.
To change to the next layout, we'll have to get the actual tab order, to change to the 'next' layout.
To get the tab order, using AUTOLISP, we would have to look in ACAD_LAYOUT dictionary...
Using Visual LISP, it is easier, and the 'layout order' is a property from the Layout object in Layouts collection.
(vl-load-com)
(defun c:ne (/ acdoc aclyt app fstlyt lyts newlyt order)
  (setq app   (vlax-get-acad-object)
        acdoc (vla-get-activedocument app)
        aclyt (vla-get-activelayout acdoc)
        lyts  (vla-get-layouts acdoc)
        order (vla-get-taborder aclyt)
  (if (and (/= order 0) (> (getvar 'CVPORT) 1))
    (command "_.pspace")
  (vlax-for lyt lyts
    (if (= (vla-get-taborder lyt) (1+ order))
      (setq newlyt lyt)
    (if (= (vla-get-taborder lyt) 1)
      (setq fstlyt lyt)
  (if newlyt
    (vla-put-activelayout acdoc newlyt)
    (vla-put-activelayout acdoc fstlyt)
  (vlax-for blk (vla-get-block (vla-get-activelayout acdoc))
    (if (= (vla-get-objectname blk) "AcDbViewport")
      (vlax-put blk 'displaylocked -1)
  (vla-ZoomExtents app)
  (princ)
Hope this helps,
Henrique
alx86
Thanks a lot hmsilva 🙂
Your routine work very well. The only thing is if the next layout is currently in an active viewport, it will zoom/extent inside the viewport instead of locking it, then zoom/extent to the layout. Beeing very beginner with lisp I barely understead them when I read them, but I've try replacing this part:
for this line:
____________________________________________________
And now it work perfectly 🙂 So the final version look like this:
  (vl-load-com)
  (vlax-for lyt lyts
      (setq newlyt lyt)
      (setq fstlyt lyt)
  (if newlyt
  (princ)
hmsilva
You're welcome, abonneau!
Glad you have it sorted!
Henrique
