how to show INSUNITS in taskbar with MODEMACRO and LISP?
boicottms
boicottms
I use this Diesel expression to convert INSUNITS in meaningfull units in a text field (very useful in title blocks) :
%<\AcDiesel $(index,$(getvar,insunits),"-,in,ft,mi,mm,cm,m,km,µin,mil,yd,Å,nm,μm,dm,dam,hm,Gm,au,ly,pc")>%
I also create a command, showing the same thing in a menù command, through the CUI, setting its name to:
~Current unit: $(index,$(getvar,insunits),"-,in,ft,mi,mm,cm,m,km,µin,mil,yd,Å,nm,μm,dm,dam,hm,Gm,au,ly,pc")Cattura2.PNG
Then I discoverd that I can show it in the status bar with the commands:
modemacro
But this is not loaded with each drawing. This should be done with lisp code. I started to play with this:
(SETVAR "modemacro"
(STRCAT "UNITS: $(index,$(getvar,insunits),"-,in,ft,mi,mm,cm,m,km,µin,mil,yd,Å,nm,μm,dm,dam,hm,Gm,au,ly,pc")")
;(replace this code with your own Diesel expression)
;end setvar
But I couldn't get it to work. I must do some stupid autolisp syntax errors.
Any help?
ВeekeeCZ
(SETVAR "modemacro" (strcat "UNITS: " "$(index,$(getvar,insunits),\"-,in,ft,mi,mm,cm,m,km,µin,mil,yd,A,nm,µm,dm,dam,hm,Gm,au,ly,pc\")"))
Or simply:
(SETVAR "modemacro" "UNITS: $(index,$(getvar,insunits),\"-,in,ft,mi,mm,cm,m,km,µin,mil,yd,A,nm,µm,dm,dam,hm,Gm,au,ly,pc\")")
The issue are inner quotation marks, read HERE
boicottms
@ВeekeeCZ
thank you, that works!
