How to set printable area by selecting objects
taitrongsong
taitrongsong
I have a printable frame, how do I set it to printable by selecting an object (polyline, block, xref) ?
EnM4st3r
so this would just set the plotarea to the points you select. If you manage to retrieve the corner points of your object extents you could adjust that.
(defun c:setplotarea (/ vlax-2d-point p01 p1 p2 layout)
  (defun vlax-2d-point (pt)
    (vlax-make-variant
      (vlax-safearray-fill
        (vlax-make-safearray vlax-vbDouble '(0 . 1))
        (list (car pt) (cadr pt))
  (setq layout (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))
        p1 (vlax-2d-point (setq p01 (getpoint "\nFirst Point for Plotarea: ")))
        p2 (vlax-2d-point (getcorner p01 "\nSecond point for Plotarea: "))
  (vla-put-plottype layout acWindow)
  (vla-setwindowtoplot layout p1 p2)
  (princ)
