how to select everything in one layer and move it to another one
f_rivaXGG6C
f_rivaXGG6C
I just intend to move what is in layer 0 and Defpoints (layers that always exist in the tables where I work) to a new layer called "00".
to do this i intend to use an .lsp file
I don't want to have the layers selected as I already know the names. even if the program repeats itself 2 times, I don't care.
to create and make the new layer "00" active, I have found that it is sufficient to do the following command:
(defun C:PFB (/)
    (command "_-layer" "_n" "00" "_c" "252" "00" "_s" "00" "")
ps. i'm using a non-English version, that's why there are "_" before each command
Moshe-A
@f_rivaXGG6C  hi,
check this
enjoy
moshe
(defun c:chglay (/ ss)
 (if (setq ss (ssget "_X" '((8 . "0,defpoints"))))
  (progn
   (command "._layer" "_Make" "00" "_Color" 252 "00" "")
   (command "._chprop" "_si" ss "_Layer" "00" "")
  ); progn
 ); if
 (princ "\nDone.")
 (princ)
f_rivaXGG6C
can I ask you what exactly you wrote?
tried it and it works fine, but i also need to import this command within another one
thank you very much
Moshe-A
@f_rivaXGG6C ,
with comments for you 😀
 (if (setq ss (ssget "_X" '((8 . "0,defpoints"))))        ; select all objects on layer 0 + defpoints
  (progn
   (command "._layer" "_Make" "00" "_Color" 252 "00" "")  ; create layer
   (command "._chprop" "_si" ss "_Layer" "00" "")         ; change layer
  ); progn
 ); if
 (princ "\nDone.")
 (princ)
f_rivaXGG6C
thank you very much
diepkhoi90
Thank mate, I got some problem that I can't change layers inside blocks. Is there any solution? Sorry my English not very well
Moshe-A
@diepkhoi90
Please, open new thread attach  sample dwg contain your block, explain what do you want to change?
Moshe
