how to rotate a lisp routine in several dwg files?
how to rotate a lisp routine in several dwg files? for example. open 1 edit 1 save 1 close 1 open 2 edit 2 save 2 close second ... Need to change many plants bylayer, and create a text Tks
hmsilva
Hello Claudio and welcome to the Autodesk Community!
One way to run a .lsp file in several dwg's is using a .scr file to open each dwg and call the routine, save, close, open the next dwg, ...
If you search at 'Search This Board' for 'batch' or 'script' or 'entire directory', you'll have many posts with this subject.
Henrique
Lee_Mac
This post may help you towards your goal.
Lee
