How to respond to an add-in's window (pop-up) in AutoCAD programmatically ?
Kh.mbkh
Kh.mbkh
When starting an AutoCAD add-in (with the command "StartPlong"), a pop-up window appears:
I wonder if it's possible to answer this window (pop-up) by checking the CheckBox1, clicking the button 2, and 3 ... programmatically.
By searching on the Net, I found some solutions (Use Spy++ to get hundle of buttons ... ) but can't come up with a solution.
N.B.: We don't have any information on the language used to create this foreign Add-in
Thanks !
paullimapa
if the add-on does not allow for command line entry with dialog window disabled, then you're stuck.
Paul Li
IT Specialist
@The Office
Kh.mbkh
Unfortunately no, I believe the only way to do that is to get the pop-up button's handle (using tools like Spy++) and then do an automatic click (via VB.NET); I'm not sure if there will be a solution with Autolisp...
_gile
What you are trying to do is hacking. You will not get any help on this forum to do that.
You need to go directly to the publisher of this add-in.
Gilles Chanteau
GileCAD
GitHub
Kh.mbkh
it seems that you didn't understand what "Hacking" is...
So for anyone who may be interested, I fixed my issue using PywinAuto (A Python library) to do Scraping.
Yasir.Aman
Can you provide some details please?
