How to rename layout tabs using extended character table?
I have a file with dozens of tabs that need to be renamed, I'm using a scrip:
Layout
r
"example 1"
"example 1 - alterações"
The problem is that the word "alterações" ends up as "alterações" after running the script.
I have no problems if I use the command Layout manually, it only happens when running the scrip.
Does anyone have an idea to fix this?
I found the answer, and I leave it here for future knowledge.
For these characters to work, you need to convert the encoding to ANSI, and that's it!
