How to pre-load scripts automatically when CAD 2017 starts
jdigiorgio
jdigiorgio
Few questions/help.
1. How do I add scripts automatically when loading CAD so i don't need to constantly load the script?  I can add a script when in a drawing, but each time I want to do the command again, i need to re-load the script.
2. Do I want to create a lisp routine to load all of my scripts in my script folder?
example.  i have a script that will isolate the reflected ceiling layers in my file. (below).  i want to use the script more than once in the file.
LAYER
THAW
S
0
ON
OFF
*-ROOF*,*-FLOR*,*FURN*,*FNSH*,*-LOW*,*-PRHT*,*-DOOR-*,*-STRS-*,*-GLAZ-*
OFF
*Y-*,*RM-ID,*RM-FLOR,*RM-??D,*-E-Z*,*-D-*,?-WALL-?-SILL,VP,VPORT
ON
*CLNG-E-ZZ*,*?-GLAZ-*,*I-FLOR-?-MLWK-HI*
OFF
*?-GLAZ-D-*,*SITE*
;;(REFLECTED CEILING PLAN)
Thanks for the help in advance.
cadffm
A Script file is not a command and you can not preload them,
but you can create own Button or Menus for import/start a scriptfile
^C^C_.script; d:/cadstuff/test.scr
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Au...
You should create your own custom cuix
Sebastian
jdigiorgio
Thanks Betreff,
I will try this.  Are there other options? create a lisp to load the scripts at startup?
cadffm
Load a script is run a script..
Do you want to run a script by every Autocad start
or by every open a file?
Every time?
For all reasons you can create a solution, but we have to know what you really want.
Perhaps you start to learn some lisp basics.
First one: Re-write your Script in Lisp by the same way: Only fireing commandline inputs with lispfunction (command).
-Layer
make
Mylayer
(command "-Layer" "make" "Mylayer" "")
Then you can create a lispdefined autocad command.
(defun c:MyCommand1 ()
(princ)
Now you can Start the new command
Command: MyCommand1
Save all your command in a Textfile with *.lsp extension
Start command APPLOAD and add your File MyFikeName.lsp to the StartSuite
Your files loads with all drawings.
This example only loads the lsp file and define your commands, it isn't start the commands.
If you want this: Ask for this.
Sebastian
