how to open an html file to a section in the file?
Julio_Soto
Advisor Advisor
Julio_Soto
so i feel I almost have this. it's a simple line like this
(startapp "explorer" "file:///C:CAD/300-drawings.html#layouts-criteria")
this opens the HTML page just fine, but it doesn't go to the section "#layouts-critria"
It does go to the section if I explicitly use chrome
(startapp "C:/Program Files/Google/Chrome/Application/chrome.exe"...etc)
but I don't want to force Chrome, I want to use the default browser.
how can I use the default browser for this?
paullimapa
works for me when I enter the following code:
(startapp "explorer" "https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/change-the-same-tag-value-extension-for-batch-attribute/m-p/13342330/highlight/true#M479320")
My default Opera browser opens to that section of the thread:
Paul Li
IT Specialist
@The Office
cadffm
if registry path not changed in newer Win versions:
(defun GetBrowser (/ str)
  (substr (setq str (vl-registry-read
      "HKEY_CLASSES_ROOT\\htmlfile\\shell\\open\\command"
  2
  (1- (vl-string-search "\" " str))
Sebastian
Julio_Soto
@paullimapa
if I copy/paste what you showed, it works. but if it's on a shared drive or my local drive , it doesn't
paullimapa
For local file which I have this thread saved under:
"C:\Autodesk\how-to-open-an-html-file-to-a-section-in-the-file.html"
I can use this lisp code to successfully open the default web browser to access section #M479451:
(command "._browser" "file:///C:/Autodesk/how-to-open-an-html-file-to-a-section-in-the-file.html#M479451")
Paul Li
IT Specialist
@The Office
Julio_Soto
ahh using "browser" was the key. I thought I tried that and it didn't work, but it's working now. maybe I typed it wrong.
thank you!
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
