How to modify lisp to do automatically copy
tencome
tencome
Hello guys,
CAD file have 3 graphics  in area (0:0) to (50:50),  I want one lisp command to perform three layer simultaneous copies and  moves.   How to modify below lisp to do automatically copy?
layer names 1, 2, and 3.
Layer 1 needs to be copied and offset horizontally by 50mm along the X-axis,
layer 2 needs to be copied and offset vertically by 50mm along the Y-axis,
layer 3 needs to be copied and offset horizontally by 50mm along the X-axis and vertically by 50mm along the Y-axis.
(defun c:CopyAndOffsetLayers (/ ss1 ss2 ss3)
  (setq ss1 (ssget '((0 . "CIRCLE,LINE,*") (8 . "1"))))
  (if ss1
    (progn
      (command "_.copy" ss1 "" "_non" '(50 0))
      (princ "\nlayer1Xoffset50\n")
  (setq ss2 (ssget '((0 . "CIRCLE,LINE,*") (8 . "2"))))
  (if ss2
    (progn
      (command "_.copy" ss2 "" "_non" '(0 50))
      (princ "\nlayer2Yoffset50\n")
  (setq ss3 (ssget '((0 . "CIRCLE,LINE,*") (8 . "3"))))
  (if ss3
    (progn
      (command "_.copy" ss3 "" "_non" '(50 50))
      (princ "\nlayer3X&Yoffset50\n")
  (princ)
(princ "\nCOPYANDOFFSETLAYERS\n")
(princ)
ryanatkins49056
Just a few quick things to double check, (I'm not allowed to download that attached file to my work machine)
Are they just a single set of entities that you wish to copy three times to three separate layers and then move them to separate positions depending on the layer they have been give?
Do you wish for the items to be selected automatically first time round or you select the items first time round manually then they are automatically selected as you process through each layer?
In the example you posted what is the "non" part of the command? (I use the english language version and that would be displacement).
komondormrex
hey,
check this
(defun c:copy_move_1_2_3 (/ move_sset)
	(if (setq move_sset (ssget "_w" '(0 0) '(50 50) '((8 . "1,2,3"))))
		(foreach object (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex move_sset))))
			(cond
				((= "1" (vla-get-layer object))
					(vla-move (vla-copy object) (vlax-3d-point 0 0) (vlax-3d-point 50 0))
				((= "2" (vla-get-layer object))
					(vla-move (vla-copy object) (vlax-3d-point 0 0) (vlax-3d-point 0 50))
				((= "3" (vla-get-layer object))
					(vla-move (vla-copy object) (vlax-3d-point 0 0) (vlax-3d-point 50 50))
	(princ)
Kent1Cooper
If what is to be Copied is everything on each Layer:
(defun C:C123 (/ ss)
  (foreach entry '(("1" (50 0)) ("2" (0 50)) ("3" (50 50)))
    (if (setq ss (ssget "_X" (list (cons 8 (car entry)))))
      (command "_.copy" ss "" (cadr entry) "")
    ); if
  ); foreach
  (prin1)
If only those things within that initial area:
    (if (setq ss (ssget "_W" '(0 0) '(50 50) (list (cons 8 (car entry)))))
    ); if
  ); foreach
  (prin1)
It's the "_X" in the first one [for finding everything that fits the filter], and the "_W" with following window corners in the second one [for defines the selection area], that make them automatic, not requiring User selection.
Kent Cooper, AIA
Kent1Cooper
By the way, this [Layer 2 instance]:
has an object-type entry in the filter that makes it pointless.  The asterisk * allows it to select any and all kinds of objects, which is what makes it usable in your sample drawing with some Polylines.  With the resulting no limit on object type, that whole filter entry serves no purpose, and this would have exactly the same result:
(setq ss2 (ssget '((8 . "2"))))
The routines in Message 4 could have object-type filtering added if needed.
And these:
need the second point of displacement [in this case Enter for use-the-first-point-as-a-displacement]:
(command "_.copy" ss2 "" "_non" '(0 50) "")
As it is, the notification is being fed in as the second point, which triggers an error.  It could also be like this:
(command "_.copy" ss2 "" "_non" '(0 0) "_non" '(0 50))
Kent Cooper, AIA
