How to modify layer name with prefix ?
tencome
Message 1 of 8
tencome
I want to modify the layer name with lisp.Change to "AAA" at one time.
 how to modify this command?    (command "rename" "layer" "BBB*" "AAA*" "")  .
All layer with same prefix "BBB",    all need change to prefix "AAA".
Original Layer:   BBB_1,    BBB_22,    BBB_123 …………
After change:   AAA_1,    AAA_22,    AAA_123…………
Replies (7)
Message 2 of 8
pbejse
command: Rename
Click Rename To: then you're done
HTH
Message 3 of 8
tencome
I want to use lisp to automatic run this command, better not select in this window.
Message 4 of 8
pbejse
Why not?
Anway, would you want that to run with be multiple patterns? or just one particular name?
--> ("BBB_" "AAA_")("WALL_" "FLOOR_")
Or you want the user to type-in the old and new prefix? which is incidentally the same as using the rename dialog
Message 5 of 8
tencome
No one particular name,    any layer with prefix "BBB"  need change to "AAA".
I don't want user to type-in new prefix,  just follow LISP commend  "AAA".
Message 6 of 8
pbejse
(defun c:BtoA (/ a oldname newname)
  (while (setq a (tblnext "LAYER" (null a)))
    (and
      (wcmatch (setq oldname (cdr (assoc 2 a))) "BBB*")
      (not
	(tblsearch "LAYER"
		   (setq newname (vl-string-subst "AAA" "BBB" oldname))
      (vla-put-name
	(vlax-ename->vla-object (tblobjname "layer" oldname))
	newname
  )(princ)
Message 7 of 8
tencome
Thank you very much.
This seemed much more difficult than I thought.
Message 8 of 8
pbejse
Anytime @tencome , Glad it helps
Not that much difficult really, it is written in such a way we can modify it later to accept multiple patterns, using "command" invites a lot of issues depending on the AutoCAD version but that's just me 🙂
It would be more complex if we include an action if the new name already exists then we may need to merge the old with the new.
