How to make selection set
danglar
Message 1 of 9
danglar
this routine can copy selected objects to pre defined layer in a same place
(defun c:ccl ( / oldsnap ss x obj)
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 167)
(princ "\n\nSelect Objects for BACKGROUND layer.")
(setq ss (ssget))
(repeat (setq x (sslength ss))
  (setq obj (ssname ss (setq x (- x 1))))
  (setq converted (ssadd))
    (command "copy" obj "" "0,0" "0,0")
    (command "chprop" "L" "" "layer" "0-BACKGROUND" "")
	(ssadd (entlast) converted)
	(command "select" converted "")
	(sssetfirst nil converted)
(setvar "osmode" oldsnap)
(princ)
I need to select all copied objects in this layer but  sssetfirst  select only last object and I need ALL of it
Can somebody help me?
Accepted solutions (3)
Replies (8)
Message 2 of 9
dbhunia
hi
try this..........
(setq ss (ssget))
  ;(setq converted (ssadd))
	;(command "select" converted "")
	;(sssetfirst nil converted)
(sssetfirst nil converted) (setvar "osmode" oldsnap) (princ) )
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 9
danglar
Thank you!
All works perfect like a charm
I almost found the solution by myself
but I just make a little mistakeSmiley Happy
Message 4 of 9
danglar
Final solution published here:
https://lispbox.wordpress.com/
Message 5 of 9
cadffm
perhaps i am wrong, but
;; ccl edited/commented
(defun c:ccl2 () ;;(setq oldsnap (getvar "osmode")) ; why dealing with osmode ??? No Pickpoints used in this Lisp..; Except copy source- and targetpoint ;;(setvar "osmode" 167) ; but i guess you want really 0,0 and not a snapped pickpoint (osmode 127) from there !? (princ "\n\nSelect Objects for BACKGROUND layer.") ;; (setq ss (ssget)) ; without IF, it's not needed ;; (setq converted (ssadd)) ; it's not needed ;; (repeat (setq x (sslength ss)) ; if you have a selectionset, why working each item by item? ;; (setq obj (ssname ss (setq x (- x 1)))) (command "_.copy" (ssget) "" "_non" "0,0" "_non" "0,0") (command "_.chprop" "_p" "" "_layer" "0-BACKGROUND" "") ;; (ssadd (entlast) converted) ; it's not needed ;; );_repeat ;; (command "select" converted "") ; it's not needed (sssetfirst nil (ssget "_p")) ;; (setvar "osmode" oldsnap) ; no change, no re-set needed (princ) )
;; ccl rewritten
(defun c:ccl3 (/ ss)
 (setvar 'CMDECHO 0)
 (if (setq ss (ssget "_:L"))
     (progn
       (command
             "_.LAYER" "_new" "0-BACKGROUND" "_on" "0-BACKGROUND" "_thaw" "0-BACKGROUND" ""
             "_.copy" ss "" "_non" "0,0" "_non" "0,0"
       (sssetfirst nil ss)
     (princ "\nNothing selected, canceled.")
  (princ)
Sebastian
Message 6 of 9
ВeekeeCZ
Hi @danglar, nice attempt!
But... the first rule of using build-in commands within the (command) function is run them as few times as possible - because they are reeeealy sloooow
Try your routine and compare with @cadffm's one on a large number of entities. You'll see the difference.
And add (setvar 'cmdecho 1) to his routine to restore the echo.
Message 7 of 9
danglar
Thanks   and @CADffm
As you see I'm trying to learn autolisp coding by my own mistakes
and your help pushing me forward (sorry for my bad English) but I thing you understand me
Message 8 of 9
ВeekeeCZ
Since you're learning, here is another very common approach.
- making a mark by saving last entity
- let a command create new entities as many as need... often we don't know how many.
- then catch all new entities from the mark to the end of the database.
(defun c:ccl3 (/ *error* ss ssnew enl)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (setvar 'CMDECHO 1)  		; since a sysvar was changed make sure to restore it back.
    (princ))
  (princ "\n\nSelect Objects for BACKGROUND layer,")
    (progn
      (setq enl (entlast))  		; save last entity - MARK
      (setvar 'CMDECHO 0)
      (command "_.LAYER" "_new" "0-BACKGROUND" "_on" "0-BACKGROUND" "_thaw" "0-BACKGROUND" ""
	       "_.COPY" ss "" "_non" "0,0" "_non" "0,0")
      (setq ssnew (ssadd)) 		; create an empty selection set
      (while (setq enl (entnext enl)) 	; while there is some next entity from the MARK
	(ssadd enl ssnew))		; add it to my selection set because it's a new
      (command "_.CHPROP" ssnew "" "_layer" "0-BACKGROUND" "")
      (setvar 'CMDECHO 1)
      (sssetfirst nil ssnew)
  (princ)
There is a difference in DRAWORDER between @cadffm's routine and mine (or your original attempt). While his changes a layer of the ORIGINAL entities, so they are in the BACK, my is changing all NEW ones being as a copy in the FRONT. I guess in this case may be even preferable to have all objects at 0-BACKROUND layer in the BACK, but usually we/I expect to change the new ones.
Message 9 of 9
danglar
It's very interesting approach. Now we can to see the solution of issue from different point of view..
Thank you for your opinion to my posts
