how to LISP routine reads text and print to csv file
Hi guys,
I know this task is simple but I'm very rusty on autolisp... I do not remember anything of it, **** Smiley Sad
I've a directory with 2000 dwgs and I need to extract 2 text from any of them and print all on a csv file.
All these dwgs have the texts (simple text) I need at precise coordinates.
Text 1 is at 291.3835, 21.7590, 0.0000
Text 2 is at 337.8941, 10.9997, 0.0000
So basically I need a routine that "reads" the content of Text 1, reads the content of Text 2 and prints these two contents in a row in a csv file, then close the current dwg and process the next one till all dwgs of the directory specified are done.
I hope to have been clear... Thanks in advance to all want to help me.
martti.halminen
This can be divided into three main parts:
1. Read the texts in one drawing
- see the documentation about the SSGET function.
- dig the actual string out of the result
2. Write the texts to the .csv file
- open the file for appending
- write the first text
- write a separator
- write the other text
- close the file
3. repeat for the next drawing
- Here the main problem is that usually AutoCAD is ran with the Windows Multiple Document Interface setting. In this case each drawing has its own Lisp environment, so a single Lisp program can't work on multiple drawings without some contortions. There are two common ways to avoid this:
A. handle the stepping between drawings from an external program
B. change to using Single Document Interface for this task.
For a one-off task that is all; if this is a recurring task you might try building this to use AutoCAD Core Console for better performance.
dbhunia
I am agree with your steps.... except the highlighted ones......
- write a separator
- close the file
By taking care of two system variables "SDI" & "LISPINIT" you can work on multiple drawings using a single Lisp Program at a time......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
martti.halminen
What did you think case B was?
