How to know that a button is to be a drop-down menu now ?
tramber
Advisor Advisor
Message 1 of 11
tramber
2017 :        2025 :
How can the users get the information now ? It is a real issue. And I am without solution and absolutely no intention to paint a black triangle on a button that is not designed for that.....
Can you see it ? On button n°8 ?
Nobody complaining about that issue in the customization forum. Where I don't usualy come....
I'd like to know if it is annoying for a lot of people.
Because my users can't understand anymore that it is an organized toolbar....
Replies (10)
Message 2 of 11
Sea-Haven
You can make your own Icons just need a BMP with 32x32 pixels, I use Paint.net to make them, and save in a location in the designated "Icon paths", see Options Files.
Message 3 of 11
paullimapa
that looks like a custom toolbar.
toolbars that come with autocad still has the small black triangle.
for example here's the Draworder toolbar:
Paul Li
IT Specialist
@The Office
Message 4 of 11
Sea-Haven
Is it an image problem or this ?
"To set the button and flyout style of a flyout on a ribbon panel (Procedure)"
Message 5 of 11
tramber
Yes, it is a custom bar.
To me, it is a bug.
What you think ? Make a try. You won't get the black triangle and it is a pitty !
Message 6 of 11
tramber
2025 : no triangle
Message 7 of 11
paullimapa
triangle is still there for me even in 2026.
this is a partial menu with the flyout in the toolbar
Paul Li
IT Specialist
@The Office
Message 8 of 11
ВeekeeCZ
The arrow is probably still there, but its color has changed (logically to white because the background is now very dark), so it's not visible on your white background. The arrow has always covered the right corner of the icon. In my opinion, there is no other way except to accept that things have developed somehow, and make the icon background transparent.
from 2025
or with the light color scheme
Message 9 of 11
tramber
You know watifink ?
This CUIX moved from my 2017 to the 2025 with no other manipulation than a click and a "Browse..." to add it as a company menu in the options first tab as you imagine.
My surprise was 100% to loose the triangle.
But, I can rebuild this from the top in 2025, I thought about it. If it works, it is a pitty that rebuilding is necessary but I will inform you if it is the case...or not.
I 'm in a hurry for the next days before holidays and it is not fundamental to those you know the toolbar (but not to the newbies in the office).
[EDIT : solution one step before.]
Message 10 of 11
tramber
Jesus ! (or any other one)
You were right..... I've just zoomed... 😁
It was visible in Paul's first message....
I am a little embarassed as it was obvious. But it is good to have support.
Message 11 of 11
tramber
4 black pixels + 2 grey (2017)
4 white pixels in 2025.....
