Visual LISP, AutoLISP and General Customization
how to insert stabicad "stempel" block in lisp?
2 REPLIES 2
g_cheung6KUDS
198 Views, 2 Replies
My company uses a third-party software called "Stabicad." When creating a "stempel" (which is a block), it will have a connection to the Stabicad database with relevant information for the drawing. This connection does not occur when inserting the "stempel" using the standard AutoCAD method.
How can I set up the block programmatically to function similarly to how Stabicad normally does? My task involves replacing these stempels, and I am looking for a way to automate several parts, if possible.
Tags (1)
2 REPLIES 2
Kent1Cooper
in reply to: g_cheung6KUDS
[I doubt we can answer that, without knowing what Stabicad does to create its linkage.  Is there a Stabicad Forum where you can raise the question?]
Kent Cooper, AIA
pendean
Here is the link to TRIMBLE support, the software company (not Autodesk) that created the software "stabicad", ask them for help
https://mep.trimble.com/en/support
TRIMBLE also has a lively and active User Forums just like these, for folks like you that use TRIMBLE software
https://community.trimble.com/communities/supportcommunity?CommunityKey=48f38a6e-5abb-4ba1-8880-972f...
AutoCAD Inside the Factory
