how to input the text height
(defun c:tri ( / TA TB TC cc1 r1 cc2 r2 dce dxf_210 xi yi i cr1 cr2 vi xt yt h1 h2 h i1 i2 key)
(command "osmode" 1)
(initget 9)
(setq cc1 (getpoint "\nPick specify start point?: "))
(initget 9)
(setq cc2 (getpoint cc1 "\nPick or specify end point?: "))
(SETQ P1 (DISTANCE CC1 CC2))
(setq th(getint "\n enter text height")) ; I want this
(grdraw cc1 cc2 1)
; (SETVAR "users3" (RTOS P1 2 2))
;(vl-vbaload "E:/FMB Cadd/GUIDELINE.dvb");testdial
;(VL-VBARUN "LTV")
(setq
Tx (if (not Tx) 65 Tx)
TA (getstring (strcat "\nEnter start point of text <" (chr Tx) ">: "))
(if (not (eq TA "")) (setq Tx (1+ (setq TA (ascii TA)))) (setq TA Tx Tx (1+ Tx)))
(setq TB (getstring (strcat "\nEnter end point of text <" (chr Tx) ">: ")))
(if (not (eq TB "")) (setq Tx (1+ (setq TB (ascii TB)))) (setq TB Tx Tx (1+ Tx)))
(setq TC (getstring (strcat "\nEnter third point of text <" (chr Tx) ">: ")))
(if (not (eq TC "")) (setq Tx (1+ (setq TC (ascii TC)))) (setq TC Tx Tx (1+ Tx)))
(initget 39)
(setq r1 (getdist cc1 (strcat "\n" (chr TA) "<----->" (chr TC) " Length: ")))
(initget 39)
(setq r2 (getdist cc2 (strcat "\n" (chr TB) "<----->" (chr TC) " Length: ")))
(grdraw cc1 cc2 0)
(setq
dce (distance cc1 cc2)
dxf_210 (trans '(0 1 0) (getvar "UCSYDIR") 0)
(if (equal (/ dce (+ r1 r2)) 1E-16)
(setq
xi (/ (+ (* r2 (car cc1)) (* r1 (car cc2))) dce)
yi (/ (+ (* r2 (cadr cc1)) (* r1 (cadr cc2))) dce)
i (cons xi (cons yi '(0.0)))
(if (and (not (zerop (- r1 r2))) (equal (/ dce (+ r1 r2)) 1E-16))
(progn
(if (= r1 (max r1 r2))
(setq cr1 cc1 cr2 cc2)
(setq cr1 cc2 cr2 cc1)
(setq
xi (/ (- (* (max r1 r2) (car cr2)) (* (min r1 r2) (car cr1))) dce)
yi (/ (- (* (max r1 r2) (cadr cr2)) (* (min r1 r2) (cadr cr1))) dce)
(progn
(if (or (> dce (+ r1 r2)) (< (+ (min r1 r2) dce) (max r1 r2)))
(prompt "\nNo intersection !...")
(progn
(setq vi (angle cc1 cc2))
(if (> r1 r2)
(setq
xt (- (/ (* (+ r1 dce r2) (- (+ r1 dce) r2)) (* 2 dce)) r1)
yt (- dce xt)
h1 (sqrt (- (expt r1 2) (expt xt 2)))
h2 (sqrt (- (expt r2 2) (expt yt 2)))
xi (/ (+ (* yt (car cc1)) (* xt (car cc2))) dce)
yi (/ (+ (* yt (cadr cc1)) (* xt (cadr cc2))) dce)
(setq
xt (- (/ (* (+ r2 dce r1) (- (+ r2 dce) r1)) (* 2 dce)) r2)
yt (- dce xt)
h1 (sqrt (- (expt r2 2) (expt xt 2)))
h2 (sqrt (- (expt r1 2) (expt yt 2)))
xi (/ (+ (* xt (car cc1)) (* yt (car cc2))) dce)
yi (/ (+ (* xt (cadr cc1)) (* yt (cadr cc2))) dce)
(setq
h (/ (+ h1 h2) 2)
i1 (polar (cons xi (cons yi '(0.0))) (+ vi (/ pi 2)) h)
i2 (polar (cons xi (cons yi '(0.0))) (- vi (/ pi 2)) h)
(princ "\n<Move cursor> for choice; <Enter>/[Space]/Right-Click for end!.")
(while (and (not (member (setq key (grread T 4 2)) '((2 13) (2 32)))) (/= (car key) 25))
(redraw)
(grdraw cc1 cc2 7)
(cond
((eq (car key) 5)
(if (< (distance i1 (cadr key)) (distance i2 (cadr key)))
(set 'i i1)
(set 'i i2)
(grdraw cc1 i 7)
(grdraw i cc2 7)
(setq
cc1 (trans cc1 1 dxf_210)
cc2 (trans cc2 1 dxf_210)
i (trans i 1 dxf_210)
(entmake
(list
'(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
(cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
(cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
(cons 8 (getvar "CLAYER"))
(cons 62 150)
(cons 6 (getvar "CELTYPE"))
(cons 370 (getvar "CELWEIGHT"))
'(100 . "AcDbPolyline")
'(90 . 3)
(if (eq (getvar "PLINEGEN") 1) '(70 . 129) '(70 . 1))
(cons 43 (getvar "PLINEWID"))
(cons 38 (getvar "ELEVATION"))
(cons 39 (getvar "THICKNESS"))
(cons 10 (list (car cc1) (cadr cc1)))
'(40 . 0.0)
'(41 . 0.0)
'(42 . 0.0)
'(91 . 0)
(cons 10 (list (car i) (cadr i)))
'(40 . 0.0)
'(41 . 0.0)
'(42 . 0.0)
'(91 . 0)
(cons 10 (list (car cc2) (cadr cc2)))
'(40 . 0.0)
'(41 . 0.0)
'(42 . 0.0)
'(91 . 0)
(cons 210 dxf_210)
(SETQ OBJ1(ENTLAST))(COMMAND "EXPLODE" OBJ1 "")
(mapcar
'(lambda (d a p / )
(entmake
(list
'(0 . "TEXT")
(cons 8 "Some layer")
'(62 . 1)
'(100 . "AcDbText")
'(10 0.0 0.0 0.0)
'(40 . th)
(cons 1 (strcat "(" (rtos d 2 2) ")"))
(cons
50
(if (minusp (cos a))
(+ pi a)
a
'(72 . 1)
(cons 11 p)
(cons 210 dxf_210)
'(100 . "AcDbText")
'(73 . 1)
(mapcar '(lambda (i / ) (distance (list (caar i) (cadar i)) (list (caadr i) (cadadr i)))) (list (list cc1 cc2) (list cc1 i) (list cc2 i)))
(mapcar '(lambda (i / ) (angle (car i) (cadr i))) (list (list cc1 cc2) (list cc1 i) (list cc2 i)))
(mapcar
'(lambda (i / ) (list (* (+ (caar i) (caadr i)) 0.5) (* (+ (cadar i) (cadadr i)) 0.5)))
(mapcar
'(lambda (x p / )
(entmake
(list
'(0 . "TEXT")
'(62 . 1)
'(100 . "AcDbText")
'(10 0.0 0.0 0.0)
'(40 . th)
(cons 1 (chr x))
'(50 . 0.0)
(cons 7 (getvar "TEXTSTYLE"))
'(72 . 1)
(cons 11 p)
(cons 210 dxf_210)
'(100 . "AcDbText")
'(73 . 1)
(list TA TB TC)
(list cc1 cc2 i)
(redraw)
(prin1)(command "osmode" 15359)
