How to implement Explode Command in Python
Does anyone know how to program in python the explode command to be applied to a dynamic block and then get its attributes?
fkp7057
why you need python for this simple AutoCAD thing.
you can use lee mac Burts upgraded Command.
Check the Below link :
http://www.lee-mac.com/upgradedburst.html
Hope this will help you.
hosneyalaa
HI
BY dynamo Python Script
https://forum.dynamobim.com/t/access-attributes-in-blocks/38147/3?u=hosneyalaa
Copyright 2019 Autodesk, Inc. All rights reserved.
This file is part of the Civil 3D Python Module.
__author__ = 'Paolo Emilio Serra - paolo.serra@autodesk.com'
__copyright__ = '2019'
__version__ = '1.0.0'
import clr
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AecBaseMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
clr.AddReference('AutoCADNodes')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references from AutoCAD
from Autodesk.AutoCAD.Runtime import *
from Autodesk.AutoCAD.ApplicationServices import *
from Autodesk.AutoCAD.EditorInput import *
from Autodesk.AutoCAD.DatabaseServices import *
from Autodesk.AutoCAD.Geometry import *
# Import references for PropertySets
from Autodesk.Aec.PropertyData import *
from Autodesk.Aec.PropertyData.DatabaseServices import *
# Import references for Civil 3D
from Autodesk.Civil.ApplicationServices import *
from Autodesk.Civil.DatabaseServices import *
# Import Dynamo for AutoCAD nodes
from Autodesk.AutoCAD.DynamoNodes import *
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
# Example function
def get_block_references_tag(input):
	Description....
	:param first_param: ....
	:returns: ....
	if not isinstance(input, BlockReference):
		return
	input = input.InternalDBObject
	if len(input.AttributeCollection) == 0:
		return []
	global adoc
	output = {}
	with adoc.LockDocument():
		with adoc.Database as db:
			with db.TransactionManager.StartTransaction() as t:
				bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
				btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
				for oid in input.AttributeCollection:
					att = t.GetObject(oid, OpenMode.ForWrite)
					output[att.Tag] = att.TextString
				t.Commit()
	return output
OUT = get_block_references_tag(IN[0])
