How to identify an object in AutoCAD drawing based on Entity Handle?
Message 1 of 9
Hi
I have a DXF file of underground stormwater layout. Attached is the image.
Highlighted is the stormwater pipelineHighlighted is the stormwater pipeline
I ran python scripts to extract the geometry. It extracted geometry along with entity handles.
My question is how can I zoom to highlighted area in the drawing based on entity handle? I am interested in the storm water pipe on Grey Street. How can I highlight just the stormwater pipe on Grey Street based on Entity Handle.
I tried (ENTGET(HANDENT"HandleID")), it displayed all the information but didn't highlight the any object in the drawing.
or
Is it possible to find the entity handle in the drawing itself?
Replies (8)
Message 2 of 9
Sea-Haven
Lets say the enget returns a "Line" so you would "zoom c pt scale to the mid point of the line. So you need a cond then say little defuns like
(defun do-line (ent / )
(setq start (cdr (assoc 10 (entget ent))))
(setq end (cdr (assoc 11 (entget ent))))
(setq mp (mapcar '* (mapcar '+ start end) '(0.5 0.5)))
(command "zoom" "C" mp 100)
(princ)
It can vary what you do now with regards to the object.
Message 3 of 9
hmsilva
or
Try
(cond ((setq ent (handent HandleID))
       (command "_zoom" "_O" ent "")
       (redraw ent 3)
      (T (princ "\nHandle not used by any entity in the current drawing..."))
Hope this helps,
Henrique
Message 4 of 9
dgorsman
In relation to the other posts, the (enget ...) function returns a list of dotted pairs with information about the provided entity.  It doesn't zoom, select, or do anything on the UI side.  It's up to the rest of the LISP code to do things with that data (in this case, nothing at all - the entity code returned from the (handent ...) call can be passed to a call to the ZOOM command).
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 9
Thanks for your reply.
I have a basic question. I am new to AutoCAD and AutoLISP programming.
I executed (ENTGET(HANDENT "HandleId")) in autocad command line. To execute the code you mentioned, I opened Visual Lisp editor from Autocad and tried your code in Visual Studio Code text editor. I ran the code and it is opening a new AutoCAD window but didn't zoom any object in the already opened drawing. How can I link my Visual Studio Code to AutoCAD? I did search few videos and they were in visual lisp and there is a tab load function. I couldn't see that in Visual Studio Code text editor.
Please help me if there are any videos explaining how to link Visual Studio Code editor to AutoCAD?
Shilpa
Message 6 of 9
Sea-Haven
hmsilva answered your request at simplest
(command "_zoom" "_O" (handent HandleID))
Message 7 of 9
Attached  is the DXF file of a stormwater line. The python program extracted the geometry into a csv file (attached). There are number of objects in "PDF_Stormwater Pipe As Con" layer with different entity handles.
What is the best approach to find the entity handle of stormwater line highighted in blue in the drawing?
Message 8 of 9
Sea-Haven
(setq hand (cdr (assoc 5 (entget (car (entsel "\nPick object "))))))
Message 9 of 9
john.uhden
I almost always like to apply cold grips to entities selected programatically...
(sssetfirst nil (ssadd (handent handle)))
That way they are not only pretty easily seen but also selected.
John F. Uhden
