How to get rid of "ADS request error"?
Message 1 of 8
Hello Community,
surfing I come across one very useful function "getpropertyvalue" it works fine until it get property name & property value of entity. But problem starts when this function has failed to get property name or property value of any property name. "It gives ADS request error"
Is there any way to check "Property Name" & "Property Available" before getting ADS request error?
Replies (7)
Message 2 of 8
Ranjit_Singh
You could use vlax-property-available-p. However, that needs a vlaobject, whereas getpropertyvalue needs an ename as its first argument. So you could do this for instance
(if (vlax-property-available-p (vlax-ename->vla-object ename1) "Length")
 (getpropertyvalue ename1 "Length")
 (princ "\nProperty not available"))
or other option
(if (vl-catch-all-error-p (vl-catch-all-apply 'getpropertyvalue (list ename1 "Length")))
 (getpropertyvalue ename1 "Length"))
Change ename1 to your variable name containing the ename of the entity. Since you are only reading the property, above is sufficient.
Edit: Read post 8 here which has a link in there. That link has more information on the function.
Message 3 of 8
Thank You Ranjit Sir,
I will try this.
Can I get back to you if I have any question regarding this?
Message 4 of 8
Ranjit_Singh
Sure. There are quite a few helpful active members here. So you will get an answer.
Message 5 of 8
Thank you Ranjit Sir,
Property values are getting without ADS request error by using both the codes.
Message 6 of 8
Is it possible to add more than one property to check in list & get values by getpropertyvalue
(if (vl-catch-all-error-p (vl-catch-all-apply 'getpropertyvalue (list ename1 "Length" "Width" "Layer ")))
(progn
(getpropertyvalue ename1 "Width")
(getpropertyvalue ename1 "Layer")
Message 7 of 8
Ranjit_Singh
It pretty much depends on what you are trying to do. You can test them all separately or combine in one statement. This is just one example using line entity
(mapcar '(lambda (x) (cons x (vl-catch-all-apply 'getpropertyvalue (list ename1 x)))) '("Length" "Angle" "MissingProperty"))
(("Length" . 2000.0) ("Angle" . 5.16545) ("MissingProperty" . #<%catch-all-apply-error%>))
"MisingProperty" throws an error. You can now use the result to check which property failed.
Message 8 of 8
Thank You Ranjit Sir.
