How to get Grid values of each inserted blocks in drawing
Yamishon_Noah
Yamishon_Noah
Please refer to attachment, I have placed several blocks inside Title Block-Border (Block name: Transmitter Conventional) and given attribute value (ex. 1 to 8) and each block I have placed in different grid (position) in drawing.
I want to export this grid value against each block inserted in excel.
For ex:
1 no. valued block placed in grid value C2
2 no. valued block placed in grid value D3
Similarly all blocks grid values placed in the drawing shall be extracted to excel (Attribute of block and its grid value).
I have thousands of blocks with attribute placed in the several drawings which I want to extract.
Kindly help me to get the same.
Otto
Hello thegreatkarthik67
It looks like you are looking for information related to datalinking between AutoCAD and Excel. Community members with similar questions found the following article(s) useful:
DATALINK (Command)
To update data links, use the DATALINKUPDATE (Command)
To provide an interface to external database tables use:DBCONNECT (Command).
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Yamishon_Noah
Hi Otto,
thanks for your reply,
Not exactly, I don't want to link excel.. I just need to extract block position (grid value) to excel which inserted in drawing.
That grid value shall be as per my title block (row A,B,C... and Column 1,2,3...)
Karthik
swieciakpawel
Hey,
I don't generally use the imperial scale, so I hope You don't mind me making example in milimeters.
I'm not really sure if the grid differs in other drawings, or if the grid size is different for each drawing (I assumed the answer - YES).
1 - I've moved the grid border to 0,0,0
2 - I've used DATAEXTRACTION to get data from blocks : TYPE, Position X, Position Y  (Excel Tab - "DataImport")
3 - I've made a second tab (Tab - "GridSpec"), with information about Your drawing
4 - I've made a lookup table (Tab - "GridSpec") , that would assign Alphabetical values
5 - On a separate tab, I've created a final table to get results:
Considering that You can import data to Excel and prepare Yourself similar Excel, I believe this won't cause many problems.
I've done it in less than 10 min, but I hope there was no obvious mistake in the example.
Kind Regards,
Pawel
Yamishon_Noah
Hi Pawel,
Thanks lot for your reply,
This almost solved my question but I have several no. of drawings (more than 100) so every time I don't want to do manually this process.
So according to your solution can we make any type of lisp/routine to make this auto?
Karthik
swieciakpawel
Hey!
If You're looking for simple automation, i guess this could be easy if You have only single type of objects that are placed on the grid. Then You could just use a single dxe and run the lisp running a single command.
(command "-DATAEXTRACTION" "C:\\????.dxe" "YES")
But for 100 drawings you'll probably be interested in some bulk operations, and here i cannot help You, as I'm not a lisp professional.
Therefore I'd recommend a follow-up question on neighbor section of this forum : https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Kind Regards,
Pawel
