How to find objects that have been given a hatch?
iBlachu
iBlachu
How to find hatching envelope for drawing objects?
Or vice versa.
How to search for drawing objects to which a particular hatch?
komondormrex
(find_hatch_bearer '()) - find objects having any hatch
(find_hatch_bearer '("ANGLE" "ANSI31")) - find objects having "ANGLE", "ANSI31" hatches
(defun find_hatch_bearer (hatch_name_list / object_dxf hatch_dxf hatch_bearer_sset)
  	(setq hatch_bearer_sset (ssadd))
	(vlax-map-collection
		(vla-get-modelspace (vla-get-database (vla-get-activedocument (vlax-get-acad-object))))
	   '(lambda (object)
				(cond
						(and
							(member '(102 . "{ACAD_REACTORS") (setq object_dxf (entget (vlax-vla-object->ename object))))
							(= "HATCH" (cdr (assoc 0 (setq hatch_dxf (entget (cdadr (member '(102 . "{ACAD_REACTORS") object_dxf)))))))
							(if (zerop (length hatch_name_list)) t (member (cdr (assoc 2 hatch_dxf)) hatch_name_list))
							(ssadd (vlax-vla-object->ename object) hatch_bearer_sset)					)
						t
  	(sssetfirst nil hatch_bearer_sset)
	(princ)
Moshe-A
@iBlachu  hi,
The quick way to get the hatch loops (boundaries) is through the hatch object.
try this HHLO command  😀
enjoy
Moshe
; Highlight Hatch Loops
(vl-load-com)
(defun c:hhlo (/ ss i j LoopObjs)
 (if (ssget '((0 . "hatch"))) ; pause for hatches
  (progn
   (setq ss (ssadd))
   (vlax-for AcDbHatch (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
    (setq i -1)
    (repeat (vla-get-NumberOfLoops AcDbHatch)
     (vla-getLoopAt AcDbHatch (setq i (1+ i)) 'LoopObjs) ; get loop objects
     (setq j 0)
     (while (>= (vlax-safearray-get-u-bound LoopObjs 1) j)
      (ssadd (vlax-vla-object->ename (vlax-safearray-get-element LoopObjs j)) ss)
      (setq j (1+ j))
     ); while
     (foreach o (vlax-safearray->list LoopObjs)
      (vlax-release-object o); dispose memory
    ); repeat
    (vlax-release-object AcDbHatch) ; dispose memory
   ); vlax-for
   (if (> (sslength ss) 0)
    (sssetfirst ss ss) ; highlight loops
  ); progn
 ); if
 (princ)
); c:hhlo
Kent1Cooper
@iBlachu wrote:
.... How to find hatching envelope for drawing objects?....
For that part, you don't need any code.  Select a Hatch object, and if it's Associative, its envelope object(s) will be selected along with it.  If it's not, right-click and choose Generate Boundary.
Kent Cooper, AIA
