How to find mleader styles
Message 1 of 11
In a drawing, how can i get a list of available mleader styles or see if a particular style is available?
Replies (10)
Message 2 of 11
dbroad
This is code from the autodesk knowledge network that should give you all the start you need.  All you need to revise is from the foreach to an assoc.  You could find it here
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-AutoLISP/file...
or just google autocad list dictionary entries
(defun c:ListDictionaries ( / ed ed1)
  (prompt "\nDictionaries in current drawing: ")
  (foreach ed (entget (namedobjdict))
    (progn
      (cond ((= (car ed) 3)
        (prompt (strcat "\n" (cdr ed))))
            ((= (car ed) 350)
        (progn
          (foreach ed1 (entget (cdr ed))
            (if (= (car ed1) 3)
              (prompt (strcat "\n  " (cdr ed1)))
 (princ)
Architect, Registered NC, VA, SC, & GA.
Message 3 of 11
(setq Acad_Obj (vla-get-activedocument (vlax-get-acad-object)))
(setq MLeader_Dict (vla-item (vla-get-dictionaries Acad_Obj) "ACAD_MLEADERSTYLE"))
(vlax-for Item MLeader_Dict
(princ "\nMleaderStyle = ")
(princ (vlax-get-property Item 'Name))
Message 4 of 11
Great this is what i was looking for! 😃
Message 5 of 11
cschnarr
@Anonymous
I found this discussion today. I am trying to make a list of all the non-annotative Multileader styles in the current drawing, to feed the list to a list box for a user selection. Your code makes a list, and prints the list. I want to store the list in a variable, but exclude any annotative Multileader Styles. Do you have any suggestion how to generate this list for use in my code?
Message 6 of 11
Sea-Haven
Have a look at this test code and in particular the Annotative property. Should give you the answer you seek.
(setq MLeader_Dict (vla-item (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE"))
(VLAX-DUMP-OBJECT ITEM)
Message 7 of 11
ronjonp
Try this:
(vlax-for i (vla-item (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object)))
		      "ACAD_MLEADERSTYLE"
  (if (= 0 (vlax-get i 'annotative))
    (setq r (cons (vla-get-name i) r))
Message 8 of 11
cschnarr
@ronjonp
What is the name of the list created? "i" ?
Message 9 of 11
ronjonp
@cschnarr wrote:
@ronjonp
'r' is the list created.
Message 10 of 11
cschnarr
@ronjonp
Got it working as desired now. Thank you for your insights!
Message 11 of 11
ronjonp
@cschnarr wrote:
@ronjonp
Glad to help 🍻
