How to find if on accoreconsole or GUI
kazfukuoka
kazfukuoka
Hi Community,
I want to do initialization at startup only if AutoCAD
is started with GUI, not for accoreconsole.
For example, in pseudo code,
(if (not ACCORECONSOLE) (command "FileDia" "1"))
Is there any way to do this?
paullimapa
ok, not tested..but I know accoreconsole does not support (layoutlist) so you can try this:
(if (not (layoutlist))(princ"accore")(princ"gui"))
Paul Li
IT Specialist
@The Office
kazfukuoka
Thanks. But on accoreconsole, it goes as follows.
Command: (if (not (layoutlist))(princ"accore")(princ"gui"))
; error: no function definition: LAYOUTLIST
Probably we need something like (ifdef layoutlist).
paullimapa
how about this which would return nil if the function does NOT exists which means you're running accoreconsole:
(member (type layoutlist) '(subr usubr exrxsubr))
Paul Li
IT Specialist
@The Office
paullimapa
or would accoreconsole allow this:
(if layoutlist (princ"gui")(princ"accore"))
Paul Li
IT Specialist
@The Office
kazfukuoka
Thank you, it works beautifully.
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
