how to execute lisp over multiple drawings
Message 1 of 32
AFTER GIVING LISP COMMAND THIS DIALOGUE WILL OPEN
Finally What my aim is to change this similar templates in multiple drawings in one folder as per input given in dialogue box at a time..
please help me
Replies (31)
Message 21 of 32
pbejse
@pessi.symb wrote:
Any example on how to use the lisp in PUBLISH command in autocad?
our office is restricting us to install softwares like ScriptPro and the like
I take it you already have a working  lisp code, all you need to do now is dump the lisp file to the "briefcase" on appload dialog and make sure you this include this line at the end of the file if you want to keep the changes on the drawing.
(vl-cmdf "._qsave")
Also, make sure the code would run upon loading
(defun c:invokeTheCommand ()
blah blah
(c:invokeTheCommand);<--- here
and then you're golden
Message 22 of 32
Sea-Haven
As much as we rarely had multiple dwgs so title block upgrade had multiple options, but in this case is not Xref a possible better way to go.
Like wise never got into it "Sheetsets".
Message 23 of 32
-didier-
Bonjour @Anonymous
Nothing to do with the question but I would like to point out a typing error in the drawing.
sacle instead of scale, right?
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 24 of 32
pessi.symb
Yes I do have a working lisp. It is already in the "briefcase" of the appload.
How am I going to call this from the publish command?
Message 25 of 32
pbejse
Check if you did follow the instructions from my previous message [ post 21 ]
If yes, then fire away and publish. I cannot vouch for the effectiveness of your program, but if everything checks out, you should be able so see the changes that your pre-loaded lisp has done to the drawing file on the pdf's.
Message 26 of 32
Scottu2
Hello Jnanadeepak,
Since your lisp routine is loaded for every drawing
use a script file to open, activate a command, save and close.
Create a text file myscript.scr
Open "c://filename1.dwg"
c:temp
qsave
quit
Open "c://filename2.dwg"
c:temp
qsave
quit
Open "c://filename3.dwg"
c:temp
qsave
quit
Activate this script from a new drawing via Script command.
If this works then the next thing to to is automate generating the script with filenames from a directory or selected files.
Message 27 of 32
pbejse
Would be nice to know how are you getting on in your hunt for running the lisp @pessi.symb
Message 28 of 32
Scottu2
Opps,
Silly me, I should have tested the script at work.
If you have a lisp routine preloaded, ie Mylisp, you can activated with the following scripts
Setting the system variable Expert to 5 prevents popup messages during startup, like plotting many files at once, then set Expert to 0 and the end of script.
I did not test error trapping when there is an error, but it appears to break the script and stop running.
expert
5
_.open "drawing1.dwg"
mylisp
_.close
_y
_.open "drawing2.dwg"
mylisp
_.close
_y
expert
0
Message 29 of 32
maratovich
Maybe this will come in handy - AutoRunLisp
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 30 of 32
dbroad
I understand you want to use lisp but AutoCAD has provided better ways of managing sheet sets via fields and the sheet set manager.  If that doesn't work for you, the best approach, I've found is to xref a titleblock with project level information and insert a block with sheet level information into each sheet, whether you put sheets in model space or in layouts.  Change the project titleblock to update that in all drawings (when xreffed).  To update sheet info, just double click on the sheet block.  No lisp required.
If you really need a batch file approach, use the core-console with script pro (free).
Architect, Registered NC, VA, SC, & GA.
Message 31 of 32
jehd
Hi!
AEC CADIUM is yet another handy software to execute scripts at several drawing files. There is also a feature to multi-handle block attributes. There are some 70 template scripts and you can easily manage your existing and new scripts.
The videos are unfortunately not available in English, but hopefully they are useful anyway.
Script video https://youtu.be/rRcGZlHycao
Stamp video https://youtu.be/pI28J7W5Q4Q
Best regards
Jesper Hedlund
Message 32 of 32
cherisa_pelen
Community Visitor
Community Visitor
Hi thank you for your solution. It worked and it has helped tremendously.
