How to Disable Custom CUI buttons
I have created a CUI file, which contain my customized buttons. I want to disable some buttons sometimes.
When I click one of my customized button, AutoCAD executes my customized command signdata. All the setting of this command are follow:
Display
Name					CustomSign
Appearance
Button Style				Large with Text (Vertical)
Group Name
Command
Command Name                            CustomSign
Description				Sign current drawing
Extended Help File
Command Display Name		        Sign current drawing
Macro					^C^Csigndata
Tags
Access
Key Tip
Tooltip Title				CustomSign
Advanced
ElementID					xxx
ElementID					xxx
Images
I want to disable this button when system variable tilemode’s value is 1, when tilemode’s value is 0, enable this button again.
I have found this page about Disable Ribbon Buttons.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Au...
This page gives a demo as follow:
$(if,$(getvar,cmdactive),~)MOVE^C^C_move
I change the Macro content from ^C^Csigndata to one of follow, but it does not work
$(if,$(eq,$(getvar,tilemode),1),~)SIGNDATA^C^Csigndata
$(if,$(eq,$(getvar,tilemode),1),~)MOVE^C^Csigndata
How should I modify the command settings?
AutoCAD official page “About Controlling the Display of Ribbon Buttons” is as follow:
You can gray out a ribbon button by using a DIESEL string expression.
When grayed out, the macro and submenus associated with the ribbon button are made inaccessible.
The following DIESEL string expression, placed in the Macros property of the Properties pane, disables the macro while another command is active.
But I don’t know how to modify my .cuix file to achive what I want.
Really appreciate your replay, thanks!
m_latz
It has been a very long time since I have written something in DIESEL, but try this:
$(if,$(getvar,tilemode),,~)SIGNDATA^C^C_signdata
regards
Markus
Dear m.latz, thanks for your replay!
I have tried the method you mentioned, but it doesn’t work. Maybe there is something wrong with my cuix file.
Could you give me a .cuix file demo that can achieve what I want?
My email is: fj100860@gmail.com
Thanks!
