How to delete the sheet in Excel?
Message 1 of 14
Hello
I would delete the sheet in Excel.
Can anyone help?
(defun c:pol ( / Excel XlsFile WorkSheets SelSht ShtName)
  (setq Excel (vlax-get-or-create-object "Excel.Application")
	XlsFile (vl-catch-all-apply 'vla-open (list (vlax-get-property Excel "WorkBooks") "c:\temp\test.xls")))
  (vlax-invoke-method XlsFile "Activate"); to activate the opened document
  (setq WorkSheets (vl-catch-all-apply 'vlax-get-property (list XlsFile "Worksheets")))
  (setq SelSht (vl-catch-all-apply 'vlax-get-property  (list WorkSheets "Item" 2)))
  (setq ShtName (vla-get-Name SelSht))
  ; =>> Here I want to delete this sheet -> ShtName
  (vl-catch-all-apply 'vlax-invoke-method  (list XlsFile "Save"))
  (vl-catch-all-apply 'vlax-invoke-method  (list XlsFile "Close"))
  (vl-catch-all-apply 'vlax-invoke-method  (list Excel "Quit"))
  (mapcar
    '(lambda (x)
       (vl-catch-all-apply '(lambda ()
			      (progn (vlax-release-object x) (setq x nil)))))
    (list Excel XlsFile WorkSheets SelSht)
Jerzy
Replies (13)
Message 2 of 14
hmsilva
Hi Jerzy, try
(vla-delete SelSht)
Hope this helps,
Henrique
Message 3 of 14
Unfortunately, this is not it.
The program went through all the code, but the effect in the XLS file could not be seen.
Jerzy
Message 4 of 14
hmsilva
Jerzy
Jerzy,
it works on this side...
In some OS the c:\Temp is not accessible to all users, try the code in a directory not in c:\, try for instance in desktop.
Hope this helps,
Henrique
Message 5 of 14
I replace "c:\temp\test.xls" to 'C:\\Users\\bajj\\Desktop\\test.xls' and still does not work.
I have full permissions on the file.
Jerzy
Message 6 of 14
hmsilva
Jerzy
Jerzy,
if you enter
(findfile "C:\\Users\\bajj\\Desktop\\test.xls")
what is the return?
I don't have any problem with the (vla-delete SelSht)
Before run the code
after run the code
Henrique
Message 7 of 14
I swapped
XlsFile (vl-catch-all-apply 'vla-open (list (vlax-get-property Excel "WorkBooks") (findfile "C:\\temp\\Mosty\\proba.xls"))))
I have included video (video.zip) to show you that for me it's not working.
Jerzy
Message 8 of 14
hmsilva
Jerzy,
I still think that the problems are permissions...
(defun c:pol (/ Excel XlsFile WorkSheets SelSht ShtName)
                      'vla-open
    (if (= (vla-delete SelSht) :vlax-true)
        (alert (strcat "\n " ShtName " was deleted... "))
        (alert (strcat "\n " ShtName " is write-protected.. "))
    (mapcar
        '(lambda (x)
             (vl-catch-all-apply
                 '(lambda ()
Henrique
Message 9 of 14
I tried a completely 'fresh' file, which I wrote as XLS. And it works.
Thank you.
And the old file was not working, perhaps because the earlier it had an extension XLSX, and I wrote to try it as XLS.
Maybe this stuck my problem.
Message 10 of 14
hmsilva
Thank you.
You're welcome, JerzyBajj
Glad you got it sorted.
Henrique
Message 11 of 14
Hello
Subject unfortunately returns.
Everything works, provided that cleared layout is empty.
If you are in this layout are any entries that you can not delete it.
How to get around this?
In Excel, it is so that as you delete a blank layout this program do not ask and deletes. How can something tab is before deleting, Excel first asks 'Are you sure'?
Message 12 of 14
hmsilva
@Anonymous wrote:
Hello
Hi JerzyBajj,
I can't test it at the moment, but delete sheet cells, save, delete the sheet, should do the trick...
                    'vla-open
                    (list (vlax-get-property Excel "WorkBooks") (findfile "D:\\temp\\Mosty\\proba.xls"))
   (vlax-invoke-method (vlax-get-property SelSht 'cells) 'delete) ; <<<<<
   (vl-catch-all-apply 'vlax-invoke-method (list XlsFile "Save")) ; <<<<<
   (mapcar
      '(lambda (x)
          (vl-catch-all-apply
             '(lambda ()
Hope this helps,
Henrique
Message 13 of 14
It works.
Thank you again.
Message 14 of 14
hmsilva
@Anonymous wrote:
It works.
Thank you again.
Glad I could help
Henrique
