how to create lisp to make a profile from text file in autocad
giscivil92
Message 1 of 13
giscivil92
Hello everyone
I have some information like this format Kilometer  Elevation as a text file!
I appreciate it if you guide me, how can I create a lisp to create a profile from a file like the above format in AutoCAD!?
Thanks for your attention
Replies (12)
Message 2 of 13
hak_vz
Simplest way
Rewrite your profile data as let say
0,100
20,80
30,90....
Place UCS origin to start from 0,0 of profile you are creating
copy all data to clipboard
start command PLINE and paste
finish PLINE command with enter
Miljenko Hatlak
Message 3 of 13
-didier-
Bonjour @giscivil92
To do what you’re asking, you’d have to give us examples.
I understand that we start from a TXT file, but what should we get as a drawing?
Thank you for helping us to help you.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 4 of 13
giscivil92
@-didier-
@hak_vz
Hi
A vertical profile with grids like this,
read the information from text file and create grid.
Message 5 of 13
hak_vz
@giscivil92 wrote:
@-didier-
@hak_vz
Hi
Sorry have no time to work on your lisp, currently at work. This lisp  is so simple but you didn't start with lisp programing.
Anyway, Align UCS along vertical axis (command UCS OB) and paste points in pline command. It takes exactly same time as open the lisp and pick starting point.
Miljenko Hatlak
Message 6 of 13
kajanthangavel
Hi, I did the same work at my previous company. I think this is help you.
(defun LWPoly ( lst )
  (entmakex
    (append
      (list
        (cons 0 "LWPOLYLINE")
        (cons 100 "AcDbEntity")
        (cons 100 "AcDbPolyline")
        (cons 90 (length lst))
      (mapcar '(lambda ( p ) (cons 10 (trans p 1 0))) lst)
(defun c:pro (/ pline ht ch)
(command "ucs" (getpoint "\nPick starting point :") "")
	(while
		(and
			(setq ch (getreal "\nType or paste Station : "))
			(setq ht (getreal "\nType or paste Hight : "))
	(setq pline (cons (list ht (- 0 ch)) pline))
(LWPoly pline)
(command "ucs" "p" )
(princ)
Message 7 of 13
giscivil92
@kajanthangavel Hi
Thanks for your attention, That's it but I want to draw those grids and labels along with polyline!
Message 8 of 13
-didier-
Bonjour @kajanthangavel
I wasn’t sure.
I haven’t worked on it yet because I thought it should be a complete program.
I’m out of time to do it right away, it’s pretty simple, you want to learn to do it, or you want we do it for you?
Question : Y coordinates must be negative in all cases?
Amicalement
DA
Message 9 of 13
autoid374ceb4990
I am just an old civil engineer and all the profiles I have ever created or seen have the distance on the X axis and the elevation on the Y axis.  Is there a reason your profile seems (to me at least) to be rotated 90 deg.?
Message 10 of 13
Sea-Haven
Next question will be how to scale in X & Y direction.
Message 11 of 13
giscivil92
@autoid374ceb4990 Yes sure, but according to specific work I need to rotate the profile 90 degree!
Message 12 of 13
giscivil92
@Sea-Haven yes you are right , that needs a scale in y direction equals 10 times bigger than x
Message 13 of 13
kajanthangavel
Try This
