How to create automatic layouts
Message 1 of 117
Hi Everyone,
Please help me to create automatic layouts for the attached drawing
Also request you to please provide me the LISP/FAS file.
The attache dwg is simple drawing. But i have 200 grids in some cases.
Please help on this.
Thank you in advance.
Replies (116)
Message 101 of 117
YAYA.SADA
Message 103 of 117
Sea-Haven
For Yada.Sada
In english (setvar 'ctab "Model") looks like (setvar 'ctab "Otyet") if I read image correct. Also (410 . "Model")
; Make new layout tabs based on block in model spce
; By AlanH July 2023
; French version for Model
(defun mktabs ( / ss obj inspt atts layname cpt bl tr ss2)
(command "zoom" "E")
(setq ss (ssget "X" '((0 . "INSERT")(2 . "E0-Cadre")(410 . "Otyet"))))
(repeat (setq x (sslength ss))
  (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
  (setq inspt (vlax-get obj 'insertionpoint))
  (setq atts (vlax-invoke obj 'Getattributes))
  (setq layname (vlax-get (nth 0 atts) 'textstring))
  (setq cpt (mapcar '+ inspt (list 212.7405 137.0 0.0)))
  (setq bl (mapcar '+ inspt (list 20 30 0.0)))
  (setq tr (mapcar '+ inspt (list 395 244 0.0)))
  (setq ss2 (ssget "WP" (list tr bl)))
  (if (= ss2 nil)
   (princ "Skip empty block")
   (progn
    (command "_.layout" "c" "Master" layname)
    (setvar 'ctab layname)
    (command "_.zoom" "E")
    (command "_.mspace")
    (command "_.zoom" "C" cpt "0.9XP")
    (command "_.pspace")
    (setq ent (ssname (ssget "x" (list (cons 0  "Viewport")(cons 410 (getvar 'ctab)))) 0))
    (setq obj (vlax-ename->vla-object ent))
    (vla-put-DisplayLocked obj  -1)
(princ)
(mktabs)
Message 104 of 117
YAYA.SADA
;;; Créer des présentation basé sur un bloc de l'espace objet
;;; Par AlanH July 2023
;;; In French
(setvar 'ctab "OBJET")
(command "ZOOM" "ET")
(setq ss (ssget "X" '((0 . "INSERER")(2 . "E0-Cadre")(410 . "OBJET"))))
(setq ss2 (ssget "FPOLY" (list tr bl)))
(if (= ss2 nil)
(progn
(command "PRESENTATION" "C" "Master" layname)
(command "ZOOM" "E")
(command "ESPACEO")
(command "zoom" "C" cpt "0.9XP")
(command "ESPACEP")
(setq ent (ssname (ssget "x" (list (cons 0 "FENETRES")(cons 410 (getvar 'ctab)))) 0))
(princ)
(mktabs)
I've always this message, i remplaced all english command by French command
"MODEL"->"OBJET"
"ZOOM" "E"->"ZOOM" "ET" for Extents
"INSERT"->"INSERER"
"WP"->"FPOLY"
"VIEWPORTS"->"FENETRES"
"_.pspace"->"_.ESPACEP"
"_.layout"->"_.PRESENTATION"
"_.mspace"->"ESPACEO"
Commande: _appload MKtabs.lsp correctement chargé(s)
Commande: type d'argument incorrect: lselsetp nil
And when i type MKTABS, the command doesn't exist
What is the "X" here in the secance (setq ss (ssget "X" '((0 . "INSERER")(2 . "E0-Cadre")(410 . "OBJET"))))
and this (princ "Skip empty block") is it a command or a information text?
and (setq ent (ssname (ssget "x" (list (cons 0 "Viewport")(cons 410 (getvar 'ctab)))) 0))
is it "Viewport or viewports"
Message 105 of 117
Sea-Haven
The code runs on load do not need Mktabs. If you want change the.
(defun c:mktabs
and
(C:mktabs)
The "X" in a ssget implies get all, across the whole dwg, includes layouts.
 (princ "Skip empty block") replace with (princ) it is used to just show objects were skipped that did not match test.
Viewport or VIEWPORT or viewport should all work. Maybe french version is viewports, to check Properties, click on a viewport.
Its getting an error due to language problem. In the version above I changed the command lines to force english translation please try as is don't change. We can add markers (princ "\n1") in the code so an see where it stops by the number got to say 5. Other wise maybe can test in VLIDE a lisp debugger for Autocad.
Will try to remove all Command and use VL which I think remains in english.
Please press F2 do a screen grab of command line so can see numbers if it does not work.
(defun c:mktabs ( / ss obj inspt atts layname cpt bl tr ss2)
(princ "\n1")
(command "zoom" "_E")
(princ "\n2")
  (if (= ss2 nil)
   (princ "")
   (progn
	(princ "\n3")
    (command "_.mspace")(princ "\n4")
    (command "_.zoom" "C" cpt "0.9XP")(princ "\n5")
	(princ "\n6")
	(princ "\n7")
  (princ "\n8")
(princ)
(c:mktabs)
Message 106 of 117
YAYA.SADA
Hello, sorry always a problem
Commande: MKTABS
1
Nécessite une distance, une valeur X ou une option.
Fonction annulée (in english Function canceled)
Spécifiez le coin d'une fenêtre, entrez un facteur d'échelle (nX ou nXP) ou
[Tout/Centre/DYnamique/ETendu/Précédent/Echelle/Fenêtre/Objet] <temps réel>:
Spécifiez le coin opposé:
For the command ZOOM, in english AutoCAD LT 2023 Help | ZOOM (Command) | Autodesk
For the commande ZOOM in French AutoCAD 2022 Aide | ZOOM (commande) | Autodesk
Message 107 of 117
Sea-Haven
You will need to get someone who codes in the French version as I can not help much more. Sorry about that.
Message 108 of 117
YAYA.SADA
Thank you so much, you have already helped me a lot.
You're the best 😉
Message 109 of 117
YAYA.SADA
hello, I hope you are well, someone was able to correct the problem I had with your Lisp (See below) however I have another problem, when I run the command, nothing happens after the 8th stage. Can you tell me why, please?
the lisp does not ask me to select the blocks
(setvar 'ctab "MODEL")
(princ "\n1")
(command "_.zoom" "_Extent")
(princ "\n2")
(setq ss (ssget "_X" '((0 . "INSERT")(2 . "E0-Cadre")(410 . "MODEL"))))
  (setq ss2 (ssget "_WP" (list tr bl)))
  (if (= ss2 nil)
   (princ "SKIP THE BLOCK")
   (progn
    (command "_.layout" "_c" "Master" layname)
(princ "\n3")
    (command "_.zoom" "_C" cpt "0.9XP")(princ "\n5")
    (setq ent (ssname (ssget "_X" (list (cons 0  "Viewport")(cons 410 (getvar 'ctab)))) 0))
(princ "\n6")
(princ "\n7")
  (princ "\n8")
(princ)
(c:mktabs)
Message 110 of 117
YAYA.SADA
Message 111 of 117
CADaSchtroumpf
@Sea-Haven
Here an international version.
I also corrected the selection by WP in CP by providing the 4 points of the polygon because 2 points in WP returns an empty selection.
(setq ss (ssget "_X" '((0 . "INSERT")(2 . "E0-Cadre")(410 . "Model"))))
  (setq ss2 (ssget "_CP" (list tr (list (car bl) (cadr tr) 0.0) bl (list (car tr) (cadr bl) 0.0))))
  (if (= ss2 nil)
   (princ "Saute le bloc vide")
   (progn
    (command "_.layout" "_Copy" "Master" layname)
    (command "_.zoom" "_Ce" cpt "0.9XP")
(princ)
(c:mktabs)
Message 112 of 117
YAYA.SADA
Thanks you so much,
you're the best of the best
Message 113 of 117
YAYA.SADA
Can you explain to me ? please
Message 114 of 117
YAYA.SADA
this is the center of the block E0-cadre
Message 115 of 117
Sea-Haven
Thanks for having a look at it.
Message 116 of 117
meena_kRTWN7
Thanks for the lisp code. it is working perfectly after installing AutoCAD VBA enabler on drawing attached "Test2.dwg".
My question is, can i make 2 layouts in single sheet. like 1 and 2 block in sheet 1 and 3 and 4 in 2nd sheet.
i have attached the file and snip of it.
Please help me on this.
Regards
Naresh Sharma
Message 117 of 117
Sea-Haven
There is no reason why you can not make as many as you want in a layout, but it requires new code, how many 1, 2, 3, 4 etc. The Mview command supports 1 2 3 4 viewports as a default entry, so just need the 2 points making the bounding box, you could then in sequence pick the points in model space and a scale with the viewports reflecting those areas of the Model space. Pick 2 or up to 4 rectangs and make a layout matching those rectangs.
New code required.
