how to convert utm to latlong
bahman.jf.68
Message 1 of 8
bahman.jf.68
Hi all, is there any lisp or Autocad command to convert a utm coordinate to latlong ?
Replies (7)
Message 2 of 8
Simple answer is probably yes. The issue is there are so many factors in converting a x y to lat long. 1st is its world dependant, all sorts of factors creep in.
You may need to use an external program, did you google.
Message 3 of 8
braudpat
Hello
Are you running ACAD MAP or ACAD CIVIL because these products have some ADE functions for Re-Projection !?
If you have a "NEW" license ACAD, since the version 2019 the package is called "ACAD including Specialized Toolsets" and ACAD MAP is included !
---- System requirements for ACAD 2004-2022 ----
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 8
hak_vz
You may try cs2cs from Proj.org
Miljenko Hatlak
Message 5 of 8
diagodose2009
You see here my solution 100%AutoLisp.The original source Was in C2 MathEquation/s.
 (princ)
    (setq con_princeax "")                       ;;;rem: you append one string each lines
  (setq;|a55647|;
	 kpi 3.14159265358979323846
	 con_pi kpi
	 ktwopi 6.2831853071795865
	 khalfpi (/ pi 2.0)
	 con_khalfpi (/ pi 2.0)
	 con_1pi4 (* pi 0.25)
	 con_3pi4 (* pi 0.75)
	 con_5pi4 (* pi 1.25)
	 con_7pi4 (* pi 1.75)
	 con_p4pi 12.56637061435917
	 con_p2pi 6.28318530717958647692
	 con_p2dpi 0.63661977236758134308
	 con_sqrt2 1.41421356237309504880
	 con_1sqrt2 0.70710678118654752440
	 con_1six 0.16666666666666666667
	 con_1three (* con_1six 2.0)
	 con_2sqrtpi 1.12837916709551257390)
    ;;;Inp: a251=int,
    ;;;rem:     a251=tchar.
    ;;;rem:   (vla-setlayoutstoplot plot salayout)
    ;;;rem:   (setq errmsg (vl-catch-all-apply 'vla-PlotToDevice (list plot "\\\\RW-PRN01\\RICOH")))
    ;;;rem:   (if (vl-catch-all-error-p errmsg)
    ;;;rem:    (prompt (strcat "\nERROR: " (vl-catch-all-error-message errmsg)))
    ;;;rem:   ))
(setq kHereAiciHeirIciAqui 0767004316 ;;rem: my-phone romanian
      errno 5100
      erprv nil)
;;;__ __ . __ __ . __ __ . __ __ . __ __ .__ __ . __ __ . __ __ . __ __ . __ __ .__ __ . __ __ . __ __ . __ __ . __ __ .
(defun dfn_var_isstr0(a094 default / rr) ;_ASSERT_OK
  (setq;|a1660|;
	 rr (if (=  (type a094) (quote SYM)) (eval a094) a094)
	 rr (if (=  (type rr) (quote STR)) rr default))
rr)
(defun if_int(a025 default / reti guru)  ;_ASSERT_OK
  (setq;|a2680|;
	 guru (quote INT)
	 reti (if (=  (type a025) (quote SYM)) (eval a025) a025)
	 reti (if (/= (type reti) guru) default reti))
reti)
(defun asserte(a251 / rr) ;_ASSERT_OK
  (setq;|a4476|;
	 errno 0
	 acad__assertNo (if (/= (type acad__assertNo) (quote INT)) 0 (+ acad__assertNo 1))) (if (/= a251 nil) (setq;|a4564|;
	 erprv erlsp
	 erlsp (strcat "@" a251 "<" (itoa acad__assertNo) ">"))) (if (=  acad__assertNo kHereAiciHeirIciAqui) (alert (strcat "Hi! eBreakPoint kHereAiciHeirIciAqui=" (itoa kHereAiciHeirIciAqui))))
erlsp)
;;;Inf: Here is starting routine
(deFun C:Q2() ;_ASSERT_OK
  (setq;|a5534|;
	 acad__assertNo (if_int acad__assertNo 0)) (if (and  (<  acad__assertNo (- 10)) (/= const_error nil)) (setq;|a5598|;
	 kHereAiciHeirIciAqui (- acad__assertNo))) (setq;|a5616|;
	 acad__assertNo 0)
 (winmain_pp_utmcoosmall_run)
(prompt "\nCommand.com : Q2[enter]\n")
(defun winmain_pp_utmcoosmall_run( / );_ASSERT_OK
  (setq;|a6452|;
	 const_ppfiletmp (if (=  (type const_ppfiletmp) (quote STR)) const_ppfiletmp "")) (if (<  (strlen const_ppfiletmp) 3) (_wndproc) (terpri))
  (setq utmx1 451602.19)
  (setq utmy1 4519076.99)
  (setq zoneutm1 "33n")
;------------------------Stdcall "pp_utm_watermocasin "
  (setq _ax (pp_utm_watermocasin utmx1 utmy1 zoneutm1))
  (setq arxgate _ax)
  (setq utmx2 (getreal "enter utmx2: "))
  (setq utmy2 (getreal "enter utmy2: "))
  ;;;;;;;;;;(setq zoneutm2 (getstring "enter utm zone: "))
  (setq zoneutm2 "32n")
  (setq _ax (pp_utm_watermocasin utmx2 utmy2 zoneutm2))
  (setq arxgate (strcat arxgate _ax))
  (setq utmx3 (getreal "enter utmx3: "))
  (setq utmy3 (getreal "enter utmy3: "))
  ;;;;;;;;(setq zoneutm3 (getstring "enter utm zone: "))
  (setq zoneutm3 "31n")
  (setq _ax (pp_utm_watermocasin utmx3 utmy3 zoneutm3))
;------------------------Stdcall "pp_dorin2tex "
  (setq _ax (pp_dorin2tex ))
  (setq arxgate (strcat _ax arxgate))
  (alert arxgate)
;;;rem:----------------------------------------------------------------------
  (command) (command ".UNDO" "_END") (princ "\nEnd")
rr)
;;;rem:---User Labels----cad_apages-----
;;;rem:---(call_copy_source)----cad_apages-----
;;o~ "   `.. - - - - .
;;\\|/   ||_|    ;;;rem:_/        \|/
;;                      \|;;;rem:
;;;Inf: ZwCad da eroare la getenv("TEMP") result=nil
;;;Out:rr:string=("".get temporally directory)(nil.none)
;;;Eg1:"C:/TEMP/"
(defun str_pathtemp ( / rr e f k)  (asserte "A131")
  (setq;|a15514|;
	 rr nil
	 f (dfn_var_isstr (getenv "TEMP"))) (if (and  (not rr) f) (setq;|a15578|;
	 rr f)) (setq;|a15594|;
	 f (if (not f) (dfn_var_isstr (getenv "TMP")) f)) (if (and  (not rr) f) (setq;|a15656|;
	 rr f)) (setq;|a15676|;
	 f (dfn_var_isstr (getvar "TEMPPREFIX"))
	 f (if (not f) (dfn_var_isstr (getenv "TMP")) f)) (setq;|a15758|;
	 f (dfn_var_isstr (getvar "XLOADPATH"))
	 f (if (not f) (dfn_var_isstr (getenv "TMP")) f)) (if (=  rr nil) (setq;|a15852|;
	 rr "")) (setq;|a15868|;
	 k (strlen rr)) (if (>  k 2) (progn  (while (and  (>  k 1) (=  (substr rr k 1) " ")) (setq;|a15964|;
	 rr (substr rr 1 (- k 1))) (progn (while (and  (>  k 1) (wcmatch rr "*[\\]*")) (if (=  (substr rr k 1) "\\") (setq;|a16090|;
	 rr (strcat (substr rr 1 (- k 1)) "/" (substr rr (+ k 1))))) (setq;|a16182|;
	 k (- k 1)))) (setq;|a16204|;
	 c (substr rr (strlen rr))) (if (/= c "/") (setq;|a16254|;
	 rr (strcat rr "/")))))) rr)
;;          ___ /^[___              _
;;         /|^+----+   |#___________;;;rem:
;;       ( -+ |____|    ______-----+/
;;        ==_________--'            \
;;          ~_|___|__
;;;Out:rr:adsretint=(0.unknown)
;;;rem:    (1.program in IntelliCAD)
;;;rem:    (2.AutoCAD)
;;;rem:    (3.ZwCad)
;;;ByA:DragneA
(Defun dfn_cadver_isicad( / rr ac lc uc)
  (setq;|a18065|;
	 ac (dfn_var_isstr (getvar "PROGRAM"))
	 rr 0) (if ac (progn  (setq;|a18135|;
	 lc (strcase ac T)
	 uc (strcase ac)) (if (wcmatch uc "ICAD*") (setq;|a18215|;
	 rr 1)) (if (wcmatch lc "acad*") (setq;|a18255|;
	 rr 2)) (if (wcmatch lc "*zwc*") (setq;|a18295|;
	 rr 3))))
rr)
;; ,~~_
;; |/\ =_ _ ~
;;  _( )_( )\~~
;;  \,\  _|\ \~~~
(defun syst_setvars(listavar / rr kg lg cf om)  ;_ASSERT_OK
  (setq;|a21136|;
	 kg 0
	 lg listavar) (progn (setq;|a21170|;
	 rr nil) (while (/= lg nil) (if (/= lg nil) (progn  (setq;|a21224|;
	 con_lastvar (caar lg)
	 om (getvar con_lastvar)
	 rr (if om (append rr (list con_lastvar om)) rr)
	 cf (cadar lg)
	 om (if (=  cf nil) nil om)
	 om (if (=  cf T) nil om)
	 om (if om (setvar con_lastvar cf) nil)
	 kg (if om (+ kg 1) kg)))) (setq;|a21522|;
	 lg (cddr lg))))
rr)
;;((^--__
;;| /\  --___ __
(defun _wndproc( / rr io kj su bya lz)
  (setq su ""
        bya "(c)VlaxCompiler v1.0"
  (setq;|a24836|;
	 const_ppfiletmp (str_pathtemp)
	 str_pathtempA const_ppfiletmp
	 const_ppfiletmp (strcat const_ppfiletmp "pagefile.sys")) (setq;|a24914|;
	 rr (atof (getvar "ACADVER"))) (if (<  rr 14.0) (alert " Warning Minim Req : AutoCAD 14.0 or highter")) (if (<  rr 15.0) (setq;|a24990|;
	 *error* nil)) (setq;|a25006|;
	 io (command "_.undo" "Auto" "On")) (setq;|a25046|;
	 kj (dfn_cadver_isicad)) (if (=  kj 2) (setq;|a25086|;
	 io (list (vl-load-com) (textscr)))) (setq;|a25134|;
	 _ax rr) (command ".UNDO" "_BEGIN") (setq;|a25170|;
	 lz (list (list "MODEMACRO" bya) (list "UCSICON" 1) (list "ISAVEBAK" 1) (list "SAVETIME" 15) (list "BLIPMODE" 0))) (setq;|a25306|;
	 _ppcx_init_vars (syst_setvars lz)) (setq;|a25338|;
	 _pp_var1chkm nil
	 lz nil
	 dfn_var_chkC "")
rr)
;;` | \____\\
;; _(      ) \
;; \-\~~~_|\  \
;Lib:free
    ;;;Inf: UTM to LatLon test
    ;;;Eg1: (pp_utmirneb 451602.19 4519076.99 "33N")
    ;;;ByA: Water Moccasin
(defun pp_utm_watermocasin(utmX utmY utmZone / rr latitude longitude len isnorthhemisphere diflat diflon c_sa c_sb e2 e2cuadrada c x y s v a1 a2 j2 j4 j6 alfa beta gama bm epsi eps nab senoheps delt tao zone $db $ol jcxz)
  (setq;|a36819|;
	 $db "\nError"
	 latitude 0
	 longitude 0
	 len (php_strlen utmZone)) (if (>  len 1) (progn  (setq;|a36995|;
	 isNorthHemisphere (substr utmZone len 1)
	 diflat (- 0.00066286966871111111111111111111111111)
	 diflon (- 0.0003868060578)
	 utmZone (substr utmZone 1 (- len 1))) (setq;|a37117|;
	 c_sa 6378137.000000) (setq;|a37133|;
	 c_sb 6356752.314245) (setq;|a37149|;
	 e2 (/ (math_pow (- (math_pow c_sa 2) (math_pow c_sb 2)) 0.5) c_sb)) (setq;|a37225|;
	 e2cuadrada (math_pow e2 2)) (setq;|a37257|;
	 c (/ (math_pow c_sa 2) c_sb)) (setq;|a37295|;
	 x (- utmX 500000)) (setq;|a37317|;
	 isNorthHemisphere (if (>  isNorthHemisphere "N") T nil)) (setq;|a37353|;
	 y (if isNorthHemisphere utmY (- utmY 10000000))) (setq;|a37387|;
	 zone (atoi utmZone)) (setq;|a37411|;
	 s (- (* zone 6.0) 183.0)) (setq;|a37439|;
	 lat (/ y (* 6366197.724 0.9996))) (setq;|a37467|;
	 v (* (/ c (math_pow (+ 1 (* e2cuadrada (math_pow (cos lat) 2))) 0.5)) 0.9996)) (setq;|a37541|;
	 a (/ x v)) (setq;|a37563|;
	 a1 (sin (* 2 lat))) (setq;|a37587|;
	 a2 (* a1 (math_pow (cos lat) 2))) (setq;|a37627|;
	 j2 (+ lat (/ a1 2.0))) (setq;|a37655|;
	 j4 (/ (+ (* 3 j2) a2) 4.0)) (setq;|a37689|;
	 j6 (/ (+ (* 5 j4) (* a2 (math_pow (cos lat) 2))) 3.0)) (setq;|a37747|;
	 alfa (* (/ 3.0 4.0) e2cuadrada)) (setq;|a37775|;
	 beta (* (/ 5.0 3.0) (math_pow alfa 2))) (setq;|a37819|;
	 gama (* (/ 35.0 27.0) (math_pow alfa 3))) (setq;|a37863|;
	 bm (* 0.9996 c (- (+ (- lat (* alfa j2)) (* beta j4)) (* gama j6)))) (setq;|a37927|;
	 b (/ (- y bm) v)) (setq;|a37955|;
	 epsi (* (/ (* e2cuadrada (math_pow a 2)) 2.0) (math_pow (cos lat) 2))) (setq;|a38023|;
	 eps (* a (- 1 (/ epsi 3.0)))) (setq;|a38057|;
	 nab (+ (* b (- 1 epsi)) lat)) (setq;|a38091|;
	 senoheps (/ (- (math_exp eps) (math_exp (- eps))) 2.0)) (setq;|a38137|;
	 delt (atan (/ senoheps (cos nab)))) (setq;|a38163|;
	 tao (atan (/ (* (cos delt) (sin nab)) (cos nab)))) (setq;|a38199|;
	 longitude (+ (* (/ delt Math_PI) 180) s)) (setq;|a38233|;
	 latitude (* (/ (+ lat (* (- (+ 1 (* e2cuadrada (math_pow (cos lat) 2))) (* (/ 3.0 2.0) e2cuadrada (sin lat) (cos lat) (- tao lat))) (- tao lat))) Math_PI) 180.0)) (setq;|a38355|;
	 rr (strcat "\nLatitud: " (rtos latitude 2 12) "\tLongitud: " (rtos longitude 2 12))) (setq;|a38451|;
	 $db rr) (str_princ $db))) (princ "\nAll done okai")
$db)
;Lib:free
(defun pp_dorin2tex( / $rr)
 (setq $rr
      "Can someone please help translate the  C ++ code in Lisp.
There is a code to go from UTM Coordinates to lang long.
«zlib=../cl_aclayer/geomcalc/2020/pp_utmcoosmall.vlax»"
 (setq $rr (if_str $rr "Library_logmessageFAILED\n"))
$rr)
;Lib:free
;;;Out:("...".is STR maxim 512characters)
;;;rem:    ;(nil.else)
;;;Lib:free
(Defun dfn_var_isstr (a094 / rr) ;_ASSERT_OK
  (setq;|a39470|;
	 rr (if (=  (type a094) (quote STR)) a094 nil))
rr)
;Lib:free
;;;Out:rr:int=(-2.error a111 is not string type)
;;;rem:           (-1. the  var is nil)
;;;rem:           (else.okai)
(defun php_strlen(a111 / rr es)
  (if (=  a111 nil) (setq;|a40874|;
	 rr (- 1)) (progn  (setq;|a40900|;
	 es (if (=  (type a111) (quote SYM)) (eval a111) a111)
	 rr (if (=  (type es) (quote STR)) (strlen es) (- 2)))))
rr)
;Lib:free
    ;;;Inp: a295: real or int numarul
    ;;;Out:rr:tchar=(error)
    ;;;rem:      ;:real=okai
(defun math_exp(a295 / rr) (asserte "A295")
  (setq;|a41730|;
	 rr (dfn_var_isnumber a295 nil)
	 rr (if (=  rr nil) (rxtrace "a295errA<>RTREAL") (exp rr)))
rr)
;Lib:free
(defun math_piA ( / rr)
  (setq;|a42315|;
	 rr (* 4.0 (atan 1.0))
	 math_pi rr)
rr)
(setq math_pi (math_piA))
(setq math.pi math_pi)
;Lib:free
    ;;;Inp: Functie de calcul al unui numar la o putere
    ;;;rem:     inlocuieste functia din lisp expt
    ;;;rem:function pwrr(x,y:real):real;(* real la putere reala *)
    ;;;rem:begin   pwrr:=exp(y*ln(x));end;
    ;;;rem:
    ;;;Inp: nr41: real sau int numarul care e ridicat la puterea
    ;;;rem:     la37:real sau int puterea
(defun math_pow(a294 la37 / rr qq ww) (asserte "A294")
  (setq;|a44060|;
	 rr nil
	 qq (dfn_var_isnumber a294 rr)
	 ww (dfn_var_isnumber la37 rr)) (if (=  qq nil) (setq;|a44156|;
	 rr (rxtrace "a294errA<>RTREAL"))) (if (=  ww nil) (setq;|a44196|;
	 rr (rxtrace "a294errL<>RTREAL"))) (if (and  qq ww) (setq;|a44234|;
	 rr (expt qq ww)))
rr)
;Lib:free
    ;;;Inf:Display a multiple princ.
    ;;;Inp:a101:list=(if first string is nil then execute the command textscr()
    ;;;rem:               before)
    ;;;Out:nil
(defun str_princ2(a101 / rr ad gq)  (asserte "A101")
  (if (=  nil (dfn_var_isstr con_princeax)) (setq;|a46204|;
	 con_princeax "")) (if (dfn_var_isstr a101) (setq;|a46244|;
	 qq (list (princ a101) (princ con_princeax))) (progn  (if (=  (car a101) nil) (setq;|a46326|;
	 gq (textscr)
	 a101 (cdr a101))) (foreach ad a101 (princ ad) (princ con_princeax))))
nil)
(defun str_princ(a101 / ) (str_princ2 a101))
;Lib:free
(defun if_str(s386 elseuser / $rr tip) ;;_ASSERT_OK
  (setq;|a48159|;
	 tip (quote STR)
	 $rr (if (=  (type s386) (quote SYM)) (eval s386) s386)) (setq;|a48237|;
	 $rr (if (/= (type $rr) tip) elseuser $rr)) (if (and $rr (=  elseuser 1)) (progn  (setq;|a48313|;
	 romania "You must sure the str MustHave>0"
	 $rr (if (>  (strlen $rr) 0) $rr elseuser))))
$rr)
;Lib:free
             (setq acet_error "")  ;;;rem: you store here all errors
(defun rxtrace(ai_error / rr qs fj qi aqui qs)
  (setq;|a51491|;
	 rr "\n"
	 qs (quote STR)) (if (/= (type acet_error) qs) (setq;|a51555|;
	 acet_error rr)) (if (/= (type ai_error) qs) (setq;|a51593|;
	 errno 5100
	 ai_error "")) (setq;|a51635|;
	 aqui (itoa acad__assertNo)) (if (/= (type erlsp) qs) (setq;|a51703|;
	 erlsp "a257errA")) (setq;|a51725|;
	 rr (strcat erlsp ":" aqui)) (setq;|a51771|;
	 acet_error (strcat acet_error "\n" rr ai_error "**")) (if (=  ai_error "!") (progn  (princ "\n<acet_error>") (princ acet_error) (princ "\n</acet_error>") (grread)))
rr)
;Lib:free
;;;inp: k120=int, real,sym
;;;Out:rr(nr.is Integer or real)(deft.else)
;;;ByA:DragneAdrian
(defun dfn_var_isnumber(k120 deft / rr ak) ;_ASSERT_OK
  (setq;|a53444|;
	 rr k120
	 ak (type rr)) (if (=  ak (quote SYM)) (setq;|a53506|;
	 rr (eval rr)
	 ak (type rr))) (setq;|a53548|;
	 rr (if (or  (=  ak (quote INT)) (=  ak (quote REAL))) rr deft))
rr)
;Lib:free
;;;rem:   Inf: pi2= este un pi rotunjit la care nr de zecimale influenteazá
;;;rem:        Calculeaza constanta PI
;;;rem:     #define PI      ((double)3.14159265358979323846)
;Lib:free
    ;;;Inf: (type(a025)==quote(INT))
    ;;;Out:rr(1.is Integer)(nil.else)
    ;;;ByA:DragneAdrian2015
  (setq;|a57028|;
	 guru (quote INT)
reti)
;Lib:free
 ;;;{$R -cad_amain_eof T229@:057294run="devcinfo.exe
(prompt "\ncommand.com: GEO2[enter]\n")
;;;rem:End of file
;;;</-cad_amain_eof>
Message 6 of 8
diagodose2009
 (princ)
  (setq;|a31431|;
	 con_pi kpi
	 khalfpi (/ pi 2.0)
      errno 5100
      erprv nil)
  (setq;|a1546|;
rr)
  (setq;|a2566|;
	 guru (quote INT)
reti)
  (setq;|a4362|;
	 errno 0
	 acad__assertNo (if (/= (type acad__assertNo) (quote INT)) 0 (+ acad__assertNo 1))) (if (/= a251 nil) (setq;|a4450|;
	 erprv erlsp
erlsp)
  (setq;|a5405|;
	 acad__assertNo (if_int acad__assertNo 0)) (if (and  (<  acad__assertNo (- 10)) (/= const_error nil)) (setq;|a5469|;
	 kHereAiciHeirIciAqui (- acad__assertNo))) (setq;|a5487|;
	 acad__assertNo 0)
  (setq arxgate _ax)
  (setq utmx2 (getreal "\nenter utmx2: "))
  (setq arxgate (strcat arxgate _ax "\n"))
  (setq utmx3 (getreal "\nenter utmx3: "))
  (setq zoneutm3 (getstring "enter utm zone(e.g. ~31a~): "))
  (alert arxgate)
  (princ "\nThe End")
rr)
;;` | \____\\
;; _(      ) \
;; \-\~~~_|\  \
;Lib:free
  (setq;|a20456|;
	 $db "\nError"
	 latitude 0
	 longitude 0
	 len (php_strlen utmZone)) (if (>  len 1) (progn  (setq;|a20632|;
	 utmZone (substr utmZone 1 (- len 1))) (setq;|a20754|;
	 c_sa 6378137.000000) (setq;|a20770|;
	 c_sb 6356752.314245) (setq;|a20786|;
	 e2 (/ (math_pow (- (math_pow c_sa 2) (math_pow c_sb 2)) 0.5) c_sb)) (setq;|a20862|;
	 e2cuadrada (math_pow e2 2)) (setq;|a20894|;
	 c (/ (math_pow c_sa 2) c_sb)) (setq;|a20932|;
	 x (- utmX 500000)) (setq;|a20954|;
	 isNorthHemisphere (if (>  isNorthHemisphere "N") T nil)) (setq;|a20990|;
	 y (if isNorthHemisphere utmY (- utmY 10000000))) (setq;|a21024|;
	 zone (atoi utmZone)) (setq;|a21048|;
	 s (- (* zone 6.0) 183.0)) (setq;|a21076|;
	 lat (/ y (* 6366197.724 0.9996))) (setq;|a21104|;
	 v (* (/ c (math_pow (+ 1 (* e2cuadrada (math_pow (cos lat) 2))) 0.5)) 0.9996)) (setq;|a21178|;
	 a (/ x v)) (setq;|a21200|;
	 a1 (sin (* 2 lat))) (setq;|a21224|;
	 a2 (* a1 (math_pow (cos lat) 2))) (setq;|a21264|;
	 j2 (+ lat (/ a1 2.0))) (setq;|a21292|;
	 j4 (/ (+ (* 3 j2) a2) 4.0)) (setq;|a21326|;
	 j6 (/ (+ (* 5 j4) (* a2 (math_pow (cos lat) 2))) 3.0)) (setq;|a21384|;
	 alfa (* (/ 3.0 4.0) e2cuadrada)) (setq;|a21412|;
	 beta (* (/ 5.0 3.0) (math_pow alfa 2))) (setq;|a21456|;
	 gama (* (/ 35.0 27.0) (math_pow alfa 3))) (setq;|a21500|;
	 bm (* 0.9996 c (- (+ (- lat (* alfa j2)) (* beta j4)) (* gama j6)))) (setq;|a21564|;
	 b (/ (- y bm) v)) (setq;|a21592|;
	 epsi (* (/ (* e2cuadrada (math_pow a 2)) 2.0) (math_pow (cos lat) 2))) (setq;|a21660|;
	 eps (* a (- 1 (/ epsi 3.0)))) (setq;|a21694|;
	 nab (+ (* b (- 1 epsi)) lat)) (setq;|a21728|;
	 senoheps (/ (- (math_exp eps) (math_exp (- eps))) 2.0)) (setq;|a21774|;
	 delt (atan (/ senoheps (cos nab)))) (setq;|a21800|;
	 tao (atan (/ (* (cos delt) (sin nab)) (cos nab)))) (setq;|a21836|;
	 longitude (+ (* (/ delt Math_PI) 180) s)) (setq;|a21870|;
	 latitude (* (/ (+ lat (* (- (+ 1 (* e2cuadrada (math_pow (cos lat) 2))) (* (/ 3.0 2.0) e2cuadrada (sin lat) (cos lat) (- tao lat))) (- tao lat))) Math_PI) 180.0)) (setq;|a21992|;
	 rr (strcat "\nLatitud: " (rtos latitude 2 12) "\tLongitud: " (rtos longitude 2 12))) (setq;|a22088|;
$db)
;Lib:free
  (if (=  a111 nil) (setq;|a23620|;
	 rr (- 1)) (progn  (setq;|a23646|;
rr)
;Lib:free
  (setq;|a24505|;
	 rr (if (numberp a295) a295 nil)
rr)
;Lib:free
  (setq;|a25057|;
	 math_pi rr)
rr)
;Lib:free
  (setq;|a26841|;
	 rr nil
	 qq (if (numberp a294) a294 nil)
	 ww (if (numberp la37) la37 nil)) (if (=  qq nil) (setq;|a26947|;
	 rr (rxtrace "a294errA<>RTREAL")) (if (=  ww nil) (setq;|a26989|;
	 rr (rxtrace "a294errL<>RTREAL")) (if (and  qq ww) (setq;|a27027|;
	 rr (expt qq ww)))))
rr)
;Lib:free
  (if (=  nil (dfn_var_isstr con_princeax)) (setq;|a28904|;
	 con_princeax "")) (if (dfn_var_isstr a101) (setq;|a28944|;
	 qq (list (princ a101) (princ con_princeax))) (progn  (if (=  (car a101) nil) (setq;|a29026|;
	 gq (textscr)
nil)
;Lib:free
(defun rxtrace(ai_error / $rr)
  (alert ai_error)
1)
;Lib:free
;Lib:free
;;;rem:    ;(nil.else)
;;;Lib:free
  (setq;|a32316|;
rr)
;Lib:free
 ;;;{$R -cad_amain_eof T229@:032512run="devcinfo.exe
;;;rem:End of file
Message 7 of 8
hak_vz
@diagodose2009
When you have such long source code, it is better to attach it as a file.
Miljenko Hatlak
Message 8 of 8
CodeDing
@bahman.jf.68 ,
If your drawing is Geo-Located, this is all you need to GET a Lat/Long (well, this returns Long, then, Lat.. because of X / Y reasons):
;; Entmake's an arbitrary GeoMarker
;; returns - ename, of marker
(defun GeoMarker ( / )
  (entmakex '((0 . "POSITIONMARKER") (100 . "AcDbEntity") (100 . "AcDbGeoPositionMarker") (90 . 0) (10 0.0 0.0 0.0) (40 . 1.0)
             (1 . "") (40 . 0.5) (290 . 0) (280 . 0) (290 . 1) (101 . "Embedded Object") (100 . "AcDbEntity") (100 . "AcDbMText")
             (10 0.1 0.1 0.0) (40 . 1.0) (1 . "") (210 0.0 0.0 1.0) (11 1.0 0.0 0.0) (42 . 9761.9) (43 . 6666.67)))
);defun
;; Gets Lat & Long of a GeoMarker
;; e - ename, of GeoPositionMarker
;; returns - point, as (Long Lat 0.0) of geo marker
(defun GeoMarkerLL (e / )
  (setq e (vlax-ename->vla-object e))
  (mapcar
    'atof
    (list (vla-get-Longitude e) (vla-get-Latitude e))
  );mapcar
);defun
;; Turns a point into (long lat) point ..ONLY useable if dwg is Geo-Located.
;; pt - point,
;; returns - point, as (Long Lat) ...since longitudes represent "x" values & Latitudes represent "y" values
(defun PT->LL (pt / e prec return)
  (if (and pt
           (setq e (GeoMarker)))
    (progn
      (setpropertyvalue e "Position/X" (car pt))
      (setpropertyvalue e "Position/Y" (cadr pt))
      (setq prec (getvar 'LUPREC))
      (setvar 'LUPREC 8)
      (setq return (GeoMarkerLL e))
      (setvar 'LUPREC prec)
      (entdel e)
      return
    );progn
  );if
);defun
(defun c:TEST ( / pt ll)
  (if (and (not (eq "" (getvar 'CGEOCS)))
           (setq pt (getpoint))
           (setq ll (PT->LL pt)))
    (alert
      (strcat
        "Your Long/Lat point is: "
        "(" (rtos (car ll) 2 5) " " (rtos (cadr ll) 2 5) ")"
      );strccat
    );alert
  ;else
    (alert "Is drawing Geo-Located? Was a point selected? Try again.")
  );if
  (princ)
);defun
Best,
~DD
