How to convert a .stl file to .dwg using Python?
tanmayms3009
tanmayms3009
Hi, I want to export a .dwg file to .stl using Python.
According to ActiveX documentation,
the export is possible only to the mentioned formats in the picture.
Is there any other way to export drawings from .dwg to .stl? Any solution is appreciated.
Thanks in advance.
stevor
Gilles Chanteau sugested a way on post:
forums.autodesk.com/t5/visual-lisp-autolisp-and-general/python-programming-in-autocad/td-p/8164948
And a search for 'DXF' and 'python' finds some.
S
tanmayms3009
Thank you @stevor.
I would like to know more specific answer. But thanks for the link again, I'll try IronPython.
Sea-Haven
Posted somewhere use STLOUT its a inbuilt command. Python should be able to call it.
tanmayms3009
Thank you @Sea-Haven
