how to change dwf to dwg
ahmadov.nurlan
ahmadov.nurlan
how to change dwf to dwg without reference from dwf?  how explode dwf reference?
dbroad
A dxf is equivalent to a drawing.  A dwf is an electronic print with layers.  It cannot be converted back to a drawing.  It can be underlaid and cropped into another drawing using AutoCAD.
Architect, Registered NC, VA, SC, & GA.
dennis
Google and you will find some converters out there, some will let you test it a bit which would be the way to go.  Another way, open the DWF and save out a PDF, then in AutoCAD you can IMPORT the PDF, which via the Settings dialog of the PDF Import you can have it come in as vectors.
