how to Change Dimension Text Color to True color
jyan2000
Message 1 of 12
jyan2000
Hello Forms
How do I change dimension text color to True Color like ( 255,0,0) ? I found a code (below) changes whole layers.
(setq col (vla-get-TrueColor lay))
(apply 'vla-SetRGB (cons col (mapcar '(lambda (n) (fix (* n 255))) (list (random nil) (random nil) (random nil)))))
(vla-put-TrueColor lay col))
I need specific Dimentionsyle's text color to be True color.
Best Regards
Victor.
Replies (11)
Message 2 of 12
pbejse
You are referring the the DimStyle text color and not to override dimension objects Text color ?
If its the former, I'm wondering why not do the task in Dimension Style Manager and the latter with Properties ( ctrl+1 ) for objects?
Message 3 of 12
jyan2000
Thanx for reply. I know that method changing DIMCLRT to true color in dimstyle manager . However I have a continuous  form of lisp must edit DIMCLRT to true color..
(defun c:ChangeDimTXTClr_LWeight ()
(Command "DIMCLRD" "256")
(Command "DIMCLRE" "256")
(Command "DIMCLRT" "256")
(Command "DIMSD1" "On")
(Command "DIMSD2" "On")
(Command "DIMSE1" "On")
(Command "DIMSE2" "On")
(Command "DIMSOXD" "On")
(Command "DIMTAD" "0")
(Command "DIMTXSTY" "ByZ")
(Command "DIMDEC" "0")
(Command "DIMTXT" "1.13")
(Command "DIMTIH" "Off")
(Command "DIMTOH" "Off")
(Command "DIMPOST" "0")
(Command "DIMTFILL" "1")
(setq SelectDim (ssget "_A" '((0 . "DIMENSION") (3 . "ByZ"))))
(command "._Chprop" SelectDim "" "c" "121" "LW" "0.09" "" "")
(princ))
Message 4 of 12
tanbqtb03
If you can, please help me a lisp to convert all objects (line, text, block.....) selected from true color <-> index color. Thanks a lot
Message 6 of 12
Kent1Cooper
The DIMCLRT System Variable for the drawing as a whole doesn't seem to like being given a value other than a 1-255 index number.  BUT I find this works to change the Dimension Text color setting of a Dimension Style [in this case, STANDARD], as an entity, to a TrueColor value [I picked a random value]:
(setpropertyvalue (tblobjname "dimstyle" "STANDARD") "dimclrt" "70,80,90")
It would not be hard to step through the Dimension Style Table and assign the same TrueColor value to each Dimension Style.
And likewise to any already-drawn Dimension objects, if desired, substituting their entity names for that (tblobjname) function.
Kent Cooper, AIA
Message 7 of 12
pbejse
Correct me if I'm wrong, what you're doing there is overriding the dimension variables but NOT saving it at all.
You can add this line at the end, then remove the ssget and Chprop bit
(command "_.dimstyle" "_save" "ByZ" "_yes")
Are you only wanting to change the TEXT color as an Override?
Message 8 of 12
Sea-Haven
Pbejse thinking the same thing.
(cons 178 256); DIMCLRT color of text 256 is ByLayer. I am sure it can be a RGB also.
(vlax-put (vlax-ename->vla-object (car (nentsel "Pick dim text"))) 'Color 4)
(command "regen")
I think for true color need to edit the AcCm....
TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000007ACC8768>
Message 9 of 12
komondormrex
since changing dim text color is sort of overriding some set value, it cannot be programmed directly and with ease, but surely it can be done.
Message 10 of 12
Kent1Cooper
Message 6 does exactly that, but it also occurs to me....  Is there some reason not to have the Dimension Style's text color be ByLayer, and just set the True color value to the Layer on which you put those Dimensions?  You can assign other colors to the other parts, if you don't want them the same color as the text.
Kent Cooper, AIA
Message 11 of 12
komondormrex
i think the op wants to differentiate some dimensions within certain dimension style with rgb color, otherwise it has no sense, since you may create as many styles with different colored dimension text as you want.
Message 12 of 12
Kent1Cooper
@komondormrex wrote:
i think the op wants to differentiate some dimensions within certain dimension style with rgb color, ....
I don't think so, because of the wording in the part of Message 1 that I quoted in Message 10.
Kent Cooper, AIA
