How to burst a polyline drawn by Polyline Fillet LISP into lines
masumiNYMDW
masumiNYMDW
Hello!
I'm an AutoLISP beginner and wanted to ask you how I can  convert a polyline drawn by the PLF LISP into lines.
It would be great if someone can add the bursting command at the end of this code.
Thank you!
(defun C:PLF ()
(command "_PLINE")
(while (= 1 (getvar "cmdactive"))
(command pause))
(command "._FILLET" "P" "R" 100 "L")
(princ)
pbejse
You mean EXPLODE?
(defun C:PLF ()
(command "_PLINE")
	(while (= 1 (getvar "cmdactive"))(command pause))
(command "_explode" (entlast))
(princ)
Kent1Cooper
@masumiNYMDW wrote:
.... how I can  convert a polyline drawn by the PLF LISP into lines. ....
In that and the Topic heading, do you really mean into Lines specifically?  After the Fillet part, assuming the lengths of the Polyline segments are appropriate to the radius, there will be arc segments in the Pollyline [and there could be even before Filleting], and Exploding will convert it into Lines and Arcs.  If you really want only Lines, something else would be needed to break down the Arcs into multiple Lines, and some criterion would be needed about how long or short they should be.
Kent Cooper, AIA
masumiNYMDW
Sorry my terminology was confusing. I wanted to explode into lines and arcs.
I got it! Thank you!
masumiNYMDW
It's exactly what I wanted and I found it very simple!
Thank you!
