How to apply Lisp routine to multiple selection of points.
dlbsurveysuk
dlbsurveysuk
I have a simple lisp routine (see below) that allows me to select a node and then inserts a cross and level text at that point.
What I would like is to be able to select multiple nodes (eg crossing box) and then insert the cross and level text (based on the Z value of each individual node) to each node in one go.
Any help appreciated.
Thanks.
(defun C:LP (/ pt tat Y olderr)
   (setq olderr  *error*             ; Initialize variables
         *error* cterr )
 (setvar "cmdecho" 0)
 (setq OSM (getvar "OSMODE"))
 (setq lll (getvar "CLAYER"))
 (setq a(getvar "textsize"))
   (command "osnap" "NODE")
   (setq pt(getpoint "Whereabouts...?"))
   (command "osnap" "NONE")
       (setq X (car PT))
       (setq Y (cadr pt))
       (setq Z (rtos (caddr PT) 2 2))
       (setq XYPT(list (car PT)(cadr PT)))
       (setq Tat (LIST X (- Y (* 2 a))))
   (command "layer" "M" "LX" "")
   (command "insert" "CROSS" XYpt a "" 0.0)
   (command "layer" "M" "LTEXT" "")
   (command "text" Tat "" 0.0 Z)
 (setvar "OSMODE" OSM)
 (command "LAYER" "S" lll "")
 (setq *error* olderr)             ; Restore old *error* handler
 (princ)
 (setvar "CLAYER" "construction")
ВeekeeCZ
Untested
(defun C:LP (/ s i pt pt tat Y olderr)
	*error* cterr )
  (if (setq s (ssget '((0 . "POINT"))))
    (repeat (setq i (sslength s))
      (setq pt (trans (cdr (assoc 10 (entget (ssname s (setq i (1- i)))))) 0 1))
      (setq X (car PT))
      (setq Y (cadr pt))
  (princ)
dlbsurveysuk
That was quick!
Thank you. tested and seems to work fine.
Looking at the code I can see (even with my rudimentary lisp experience) roughly what is going on.
Thanks again. That should save me some time in certain situations.
Sea-Haven
Maybe a couple of suggestions
Only need layer "M" once at start then use (setvar 'clayer xxxx) a better way is (tblsearch "layers" "LX") it will return T if exists. If not then make it.
(command "layer" "M" "LX" "") ; check does exist
(setvar 'clayer "LX")
(setvar 'clayer "LXTEXT")
(setq lll (getvar "CLAYER")) ; used at start
(setvar 'clayer lll) ; used at end
