How to Add a Dimension Override to an Existing Dimension having Overrides?
scot-65
Advisor Advisor
scot-65
I have an existing dimension that has an override applied to it.
For example, I'll use DIMTAD = 4.
The "base" dimension style has DIMTAD set to 1.
I want to add another override to this existing dimension.
For example, DIMTFILL = 1.
The "base" dimension style has DIMTFILL = 0.
Using the command "-DIMSTYLE" "Apply" method will remove
the first override when the second is applied. The dimension
is gathered using a selection set.
How can one inject the second override to the dimension without
removing the first?
(In other words, I am looking for an alternative to the -Dimstyle
Apply method of updating an existing dimension object)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Ranjit_Singh
Maybe I am not understanding the question, but simply updating the property of the object updates it.
(setpropertyvalue (car (entsel)) "dimtfill" 1); in place of (car (entsel)) pass the ename if calling in routine
Kent1Cooper
Try the DIMOVERRIDE command -- asks you which Dimension Variables you want to override [you can specify any number of them], values for them, and which Dimension(s) you want to apply them to, as far as I recall without changing any other DimVar values for the selected Dimension(s) [though I don't have AutoCAD running right now to check].
Kent Cooper, AIA
scot-65
Both suggestions have merit on how they execute
and both do the same thing.
However, both will not remove the override to a restored
condition unless the entire dimension object is restored.
*DirtyCAD*.
[In other words, once an override is applied it (DFX) will never
go away even though the override value equals the value set
by the dimension style].
Thanks for the assistance Kent and Ranjit.
Scot-65
