How Save drawing into older version in ObjectDBX method.
In my current task I am use AutoCAD electrical 2018 , develop customize tool which open 100's of drawings file in ObjectDBX and change font style, and save it. here I observe after open and save file in ObjectDBX , by default file saved into AutoCAD Current version. (AutoCAD 2018, even though you set save type option is older version).
To solve this issue I am change save type option to (AutoCAD 2010) but due to open and save file in ObjectDBX again drawing files save by default in AutoCAD 2018.
on internet I found solution for change save type option in AutoLISP but all answer need to open drawing and then save it. but in my case I am not directly open drawing file, I am open file  using ObjectDBX  method.
is any one know how to change save type of drawing file in ObjectDBX  method.
_gile
You should try the SaveAs method (vla-SaveAs ...)
Gilles Chanteau
GileCAD
GitHub
cadffm
The FielType option is not available in objectDBX (thats why the external Reference-Manager also only save in the native file format version).
As Workaround you can use the accoreconsole(acc),
v1) Do all in acc
v2) Start acc after the odbx-job (incl. save)
In acc you can use the normal "saveas" command.
Sebastian
