How manipulate a dynamic block with lisp
Anybody out there try to insert then manipulate a dyno block with lisp -
where do I start ??
I would like to stretch & scale parts via lisp instead of manually on the
screen - more specifically
it would be cool if parts would stretch, flip, scale etc based on an
attributes' value or character
length whenever the attribute was edited. Ideas ??
Scott
You can use Tool Palettes to do this as you insert the block.
Check out the routines in the file below...
; shows what variables there are in your block
(defun c:tdb ()
(setq obj (vlax-ename->vla-object (car (entsel))))
(if (= (vlax-get-property obj 'isdynamicblock) :vlax-true)
(progn
(setq v (vla-getdynamicblockproperties obj))
(setq vval (vlax-variant-value v))
(setq sal (vlax-safearray->list vval))
(setq salnth (length sal))
(setq count 0)
(while (/= count salnth)
(vlax-dump-object (nth count sal))
(setq count (+ count 1))
(print "Not a dynamic block")
(setq count nil)
(princ)
;; changes a given variable in your block
(defun chgdynprop (e propname newval / obj v vval sal tot i)
(setq obj (if (= (type e) 'vla-object) e (vlax-ename->vla-object e)))
(progn
tot (length sal)
i 0
(while (< i tot)
(if (= (vlax-get-property (nth i sal) "PropertyName") propname)
(progn
(vlax-put-property (nth i sal) "Value" newval)
(setq i tot)
(setq i (1+ i))
;; reads a given variable in your block
(defun getdynprop (e propname / obj v vval sal tot i curval)
(progn
tot (length sal)
i 0
(while (< i tot)
(progn (setq curval (vlax-get-property (nth i sal) "Value")) (setq i tot))
(setq i (1+ i))
(if curval (vlax-variant-value curval))
;; returns a selection set of blocks with the same effectivename
;; example use:
;; (setq dbselset (ssdblk "MyDynBlockName"))
(defun ssdblk (effname / ssx ssf c en)
(setq ssx (ssget "X" (list (cons 2 (strcat effname ",`*U*")))))
(setq ssf (ssadd)
c 0
(if ssx
(repeat (sslength ssx)
(setq en (ssname ssx c)
c (1+ c)
(if (= (print (vla-get-effectivename (vlax-ename->vla-object en))) effname)
(ssadd en ssf)
ssf
;; find dynamick blocks
;; a command line function to select all dynamic blocks
;; with the same "effectivename"
(defun c:fdblk (/ en obj effname)
(setq en (car (entsel)))
(if en
(progn (setq obj (vlax-ename->vla-object en))
(if (vlax-property-available-p obj 'effectivename)
(progn (setq effname (vlax-get-property obj "effectivename"))
(command "Select" (ssdblk effname))
(prompt "\nNot a block.\n")
(princ)
Scott
You have to dig a little deeper that with standard blocks but it's not hard. Attached is a few sample programs, posted here a few weeks ago by others, that read and alter dynamic blocks. I find it more intuitive if I name my block controls things like "Door Size" that the default "Distance1" or the like.
Ron
Thanks guys - now I've got something to go on and it looks exciting to me !
"Scott McFarren" wrote in message
news:5135213@discussion.autodesk.com...
where do I start ??
Scott
thanks guys - you got me started and your suggestions have inspired me to
tackle
more code like this.
Scott
where do I start ??
Scott
