How make transparencydisplay toggle
ht23624
ht23624
How make transparencydisplay toggle keyboard shortcuts in cui? For example F1 key work  turn on off.
To me It looks difficult make toggle micro.
like this Toggles Polar Mode
^P'_.autosnap $M=$(if,$(and,$(getvar,autosnap),8),$(-,$(getvar,autosnap),8),$(+,$(getvar,autosnap),8))
cadffm
in tooltip you see the variable in question: TRANSPARENCYDISPLAY
in help you the valid values [F1] -> 0 off, 1 on
and also how DIESEL function IF works.
All together, you can create a Macro like this: ^P'_.TRANSPARENCYDISPLAY;$M=$(if,$(and,$(getvar,TRANSPARENCYDISPLAY),1),0,1)
The part about keyboard shortcuts
You can create your own key-combinations or re-define an existing one.
(I wouldn't redefine a standard, but that'S your choice)
https://help.autodesk.com/view/ACD/2026/ENU/?guid=GUID-9970E91B-A4F5-405C-99C1-46AD804A8858
Sebastian
cadffm
^P don't show the steps in commandline
' do it transparent - so a running command will not cancel by this macro
_ it follow the engl. commandname (this way, the command works in all language versions)
. use the original command (it is possible that plugins re-defined the normal command, the period forcing the original one)
TRANSPARENCYDISPLAY is the commandname (the englisch one)
; Semicolon is an ENTERhit in menumacros, to send the input to the program
$M= like send feedback to Acad/commandline / here starting a DIESELexpression
$(if, IF
$(and, AND
$(getvar,TRANSPARENCYDISPLAY), feedback/value of TRANSPARENCYDISPLAY variable
1 is 1
), end of AND expression, which is a test for "all values are 1"? to verify if transparencydisplay is currently set to 1 (or not to 1)
0, send 0
1 send 1
) end of IF expression
HTH
Sebastian
ВeekeeCZ
I found convenient to redefine Fx keys, those are most efficient toggles. BUT I would discourage from F1 specifically, just because it's the trouble one. There is some bug which prevents full HELP redefinition.
cadffm
👍also redefine CTRL+C/CTRL+V CAN run into problems.
So, the simple rule is: Do not redefine standards.
The other side of that simple rule of thumb is:
Do you know how the program works in the standard version?
Can you help yourself?
Then do what you want 😊
Sebastian
ht23624
Thank you very much. I think I can apply it in the way you told me. I always have trouble pressing the middle mouse button and panning. The middle mouse button is too hard. There is no suitable mouse. I would like to hear your valuable opinion. Should I do a lot of middle finger exercises?
cadffm
I would further search for a suitable mouse, there are thousands.
Sebastian
