How I Select *U blocks or How I select block by name "*U27" from entire drawing
Hi All,
Good Day..
new to forum here,
Looking for help in LISP coding to select single Block Automatically on screen by Block name Through lisp code from entire drawing .
I trying many codes as follows.
(setq ss(ssget "x" (list(cons 0 "insert") (cons2 "*U27"))))
( setq anonymus-ss (ssget "x" (list (cons 0 "INSERT") (cons 2 "*U27"))))
(setq ss (ssget "_x" '((0 . "INSERT") (2 . "YourBlockNameHere")
but it not work properly i cant select single Block By Block Name
Your help in this highly appreciated.
Regards
TechTeam Zener
Accepted solutions (3)
cadffm
U are knowing the this blockname can be change with the next time open the drawing?
(sssetfirst nil (ssget "_X" '((0 . "INSERT")(2 . "`*U*"))))
Please read about WCMATCH / Wildcards [F1]. You have to quote the * with ` for char compare literally.
Sebastian
cadffm
And if you are not the creator of Blockreference (command insert) or if we talk about dynamic blocks,
i am sure not all blockreferences you want are refered the same block.
Select all symbols by hand and check there Blockname in properties palette CTRL+1,
is ther one name (*U27) or *varies*?
Sebastian
john.uhden
Place a reverse quote before the aterisk so that the filtering treats the asterisk as a character, not a wildcard.
'(`*U27)
John F. Uhden
Good Day!!
Your help in this highly appreciated. but i using Following code
(sssetfirst nil (ssget "_X" '((0 . "INSERT")(2 . "`*U27*"))))
but code will select other 2 -3 Block at the same time.
but selected block name is different (U270, U275 , U274) as per my attach  jpg. file.
So how i select particular single Block ? as per above lisp code.
can we do one thing,  select single Block Automatically on screen by Block Name ("U27") and Block Layer Name ("Left View-Support") Through Lisp code from entire Drawing.
Regards
TechTeam Zener
cadffm
You didn't commented my comments above.
I wrote about where you can read about WILDCARDs in AutoCAD: F1 - wcmatch
About DXF-codes too: Click - Groupcode 8 is for Layer
(sssetfirst nil (ssget "_X" '((0 . "INSERT")(2 . "`*U27")(8 . "Left View-Support"))))
get
INSERTs
only of BLOCK "*U27"
only on Layer "Left View-Support"
Sebastian
Thank you for your valuable comments.
It is working fine.
Thank you once again.
Regards
TechTeam Zener
