How do you make a tool to open a drawing from a tool palette?
tiger4956
tiger4956
Hi, I'm trying to make a tool on a custom tool palette that will open a drawing.
The following command line works, but I have to press enter to complete the command and open the drawing. First, set FILEDIA=0 or this won't work at all.  The "open" command is one of the Express tools.
^C^C_open "D:\Dropbox\Acad\Steel Shapes.dwg";
The semi-colon at the end is supposed to be the same as pressing "Enter", but it doesn't work.  I also tried a space and ^M, which are also supposed to be the same as pressing enter.  I also tried replacing back-slashes with forward slashes, it still works the same, I still have to press enter to open the drawing.
I tried replacing "_open" with ^O but found it toggling ortho instead of opening.
Rob
hmsilva
Hi Rob,
if SDI=1 your code will works as expected.
If you are not using LT, I would suggest something like this
^C^C(vl-load-com);(vla-activate (vla-open (vla-get-documents (vlax-get-acad-object))"D:/Dropbox/Acad/Steel Shapes.dwg"));
Hope this helps,
Henrique
tiger4956
Thank you very much!  Your code worked exactly as expected.  Some of my tool palettes are getting bloated, and in some cases I would just rather open the source drawing and copy-paste what I need.
Thanks again!
Rob
hmsilva
You're welcome, Rob!
Glad I could help
Henrique
