How do I display a list of layers in a dcl list-box?
I have the list of layers ready but i'm not sure how to display it in my menu. Any help is appreciated.
rkmcswain
The title of your post says "dcl list box", but the subject says "in my menu"?
Which one of these are you trying to do?
If the former, presuming you have a list of layers named 'laynames' and your list box control is named "lay", do it like this.
(start_list "lay")
(mapcar 'add_list laynames)
(end_list)
If you're looking for a ready made list box, ready for your list of layers, see this.
R.K. McSwain     | CADpanacea | on twitter
Sorry i meant in my list box.
Sea-Haven
This is the one I use by Alan Thompson
  ;; List Select Dialog (Temp DCL list box selection, based on provided list)
  ;; title - list box title
  ;; label - label for list box
  ;; height - height of box
  ;; width - width of box
  ;; multi - selection method ["true": multiple, "false": single]
  ;; lst - list of strings to place in list box
  ;; Alan J. Thompson, 09.23.08 / 05.17.10 (rewrite)
(defun AT:ListSelect (title label height width multi lst / fn fo d f)
  (setq fo (open (setq fn (vl-filename-mktemp "" "" ".dcl")) "w"))
  (foreach x (list (strcat "list_select : dialog { label = \"" title "\"; spacer;")
                   (strcat ": list_box { label = \"" label "\";" "key = \"lst\";")
                   (strcat "allow_accept = true; height = " (vl-princ-to-string height) ";")
                   (strcat "width = " (vl-princ-to-string width) ";")
                   (strcat "multiple_select = " multi "; } spacer; ok_cancel; }")
    (write-line x fo)
  (close fo)
  (new_dialog "list_select" (setq d (load_dialog fn)))
  (start_list "lst")
  (mapcar (function add_list) lst)
  (end_list)
  (setq item (set_tile "lst" "0"))
  (action_tile "lst" "(setq item $value)")
  (setq f (start_dialog))
  (unload_dialog d)
  (vl-file-delete fn)
  (if (= f 1)
    ((lambda (s / i s l)
       (while (setq i (vl-string-search " " s))
         (setq l (cons (nth (atoi (substr s 1 i)) lst) l))
         (setq s (substr s (+ 2 i)))
       (reverse (cons (nth (atoi s) lst) l))
      item
Asocierea_Gur_Sim
Very nice. Thanks!
