how create .CSV excel file?
U want to create .CSV excel file to write coordinate ...
ALso read that file and extract data from file...
Sorry i want to create...
hmsilva
Hello nitingothi11 and welcome to the Autodesk Community!
If you use the 'Search This Board' tool, you will find many thread on this subject, ex.
export to csv
import csv coordinates
Hope this helps,
Henrique
Jonathan3891
Autocad already has that built in.
Try TABLEEXPORT
Jonathan Norton
Blog | Linkedin
hgasty1001
A CSV file has nothing special, it's just a txt file with .csv extension, just respect the format: string + delimiter+string +delimiter...in your coding. So you can write a CSV file with plain autolisp functions: open, write-line, close. About reading the file, you only need to "split" each line into a list.
I'm assuming you know how to codea simple Autolisp program.
Gaston Nunez
