How can taken kilometer label from section in model and show in layout for each layout separatly!?
giscivil92
Message 1 of 13
giscivil92
Hi @everyone
I have a problem, unfortunately I couldn't solve it with civil 3D!
I want to show the kilometre label on the layout taken from the model from the section view like this!?
Otherwise, i have to write manually for each layout separately!
Replies (12)
Message 2 of 13
paullimapa
You can create a separate pspace vport the size that shows that label and copy that vport into each layout you want that to be shown
Paul Li
IT Specialist
@The Office
Message 3 of 13
giscivil92
@paullimapa Hi
What do you mean!? I haven't understood!
Actually, I am looking for to find a way to do it automatically because It might be too many layouts!
Message 4 of 13
paullimapa
In any layout you need to use the Mview command to create a vport that looks into a view in model space. This is how you use layouts to see what you’ve drawn in Model tab for plotting. Share your drawing with this label in the model view and I can always create the layout vport for you looking at this label that’s in Model tab
Paul Li
IT Specialist
@The Office
Message 5 of 13
giscivil92
@paullimapa
I shared the drawing.
Message 6 of 13
paullimapa
maybe because I only have AutoCAD but not Civil3d but this is what I see in layout:
Paul Li
IT Specialist
@The Office
Message 7 of 13
giscivil92
@paullimapa
Yes I said that I use civil 3d
Message 8 of 13
paullimapa
But the solution I propose should be the same. I just cannot visually show you since I do not have Civil3d
Paul Li
IT Specialist
@The Office
Message 9 of 13
paullimapa
Message 10 of 13
giscivil92
@paullimapa this is not what I need it!
Actually, I have 50 layouts and there are 3 sections or kilometres in each layout I am looking for a lisp or something that takes kilometres from model space and shows in the layout for each layout separately!
Message 11 of 13
Sea-Haven
My Bricscad
I dont think you can do what you want with CIV3D I have not seen that label, the cross sections are a proxy type object which makes things complicated, AECC_GRAPH_SECTION_VIEW.
If you can output as Cad objects then a possible solution, is to go to each layout, jump into viewport and get the red chainage text take start & end, then write label. I have no idea where to start with the proxy object.
Message 12 of 13
giscivil92
@Sea-Haven Hi
If can do it with AutoCAD could you please show me? I have tired with civil 3d!
Message 13 of 13
Sea-Haven
When making the cross sections need to make as Autocad objects. Should be in options, else there is a convert CIV3D objects to Acad objects. Then can do something.
