How can make Text Alignment zero
jayhar
Advisor Advisor
jayhar
Hi, how can make Text Alignment Z value 0 in Properties. I am using AutoCAD 2015.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Simply select texts and show properties. In properties chart you can change Insertion point and Textalingment points Z values to 0. But with lisp it can be
(DEFUN c:textz ()
  (setq secim (ssget (list (cons 0 "TEXT"))))
  (setq secimlist (vl-remove-if 'listp (mapcar 'cadr (ssnamex secim))))
  (foreach obje secimlist
    (setq objevla (vlax-ename->vla-object obje))
    (if (= (vlax-get-property objevla 'Alignment) 0)
      (progn
        (setq point (vlax-safearray->list  (variant-value (vlax-get-property objevla 'InsertionPoint))))
        (setq point (vlax-3d-point (car point) (cadr point) 0))
        (vlax-put-property objevla 'InsertionPoint point)
      (progn
        (setq point (vlax-safearray->list  (variant-value (vlax-get-property objevla 'TextAlignmentPoint))))
        (vlax-put-property objevla 'TextAlignmentPoint point)
Kent1Cooper
@jayhar wrote:
Hi, how can make Text Alignment Z value 0 in Properties. ....
Clarify the question -- can you just pick in that slot and type in 0?  Or can you use FLATTEN?  Or are you looking for a way to do it to multiple Text objects in a routine, with which for some reason FLATTEN won't do what you need?  Or ... ?
Kent Cooper, AIA
