Message 1 of 14
how can I use this LISP? SSM sheet renumbering
I found a lisp that should solve my problem renumbering sheet in SheetShetManager:
http://www.theswamp.org/index.php?topic=52362.msg593054#msg593054
(progn
;; Unless noted otherwise all code herein © 2007-2016 Michael Puckett.
;; Code is provided in the hope that it may be useful or educational
;; but WITHOUT ANY WARRANTY; without implied warranty of MERCHANTABILITY
;; or FITNESS FOR ANY PARTICULAR PURPOSE.
;; Thanks for leaving source notes and attribution intact.
;; Correspondence: [email protected].
(defun _ReadStream ( path len / fso file stream result )
;; 2007 Michael Puckett (see tinyurl.com/io-streams)
;; If the file is successful read the data is returned as
;; a string. Won't be tripped up by nulls, control chars
;; including ctrl z (eof marker). Pretty fast (feel free
;; to bench mark / compare to alternates).
;; If the caller wants the result as a list of byte values
;; simply use vl-string->list on the result:
;; (setq bytes
;; (if (setq stream (_ReadStream path len))
;; (vl-string->list stream)
;; Arguments:
;; path Fully qualified path and file name.
;; len Number of bytes to read. If non numeric, less
;; than 1 or greater than the number of bytes in
;; the file everything is returned.
(vl-catch-all-apply
'(lambda ( / iomode format size )
(setq
iomode 1 ;; 1 = read, 2 = write, 8 = append
format 0 ;; 0 = ascii, -1 = unicode, -2 = system default
fso (vlax-create-object "Scripting.FileSystemObject")
file (vlax-invoke fso 'GetFile path)
stream (vlax-invoke fso 'OpenTextFile path iomode format)
size (vlax-get file 'Size)
len (if (and (numberp len) (< 0 len size)) (fix len) size)
result (vlax-invoke stream 'read len)
(vlax-invoke stream 'Close)
(if stream (vlax-release-object stream))
(if file (vlax-release-object file))
(if fso (vlax-release-object fso))
result
(defun _WriteStream ( path text mode / fso stream file result )
;; Return the file size if the file is successfully written
;; to, otherwise nil. Will write all ascii chars to file
;; including nulls. If the caller wants to pass a list of
;; byte values to the function just call it like so:
;; (_WriteStream
;; path
;; (vl-list->string '(87 111 111 116 33))
;; mode
;; Arguments:
;; text Text to write to file.
;; mode "a" to create/append,
;; "w" to create/overwrite (default)
(setq mode (if (member mode '("a" "A")) "a" "w"))
(vl-catch-all-apply
'(lambda ( / format )
(setq fso (vlax-create-object "Scripting.FileSystemObject"))
(cond
( (or (null (findfile path)) (eq "w" mode))
(setq stream
(vlax-invoke
fso
'CreateTextFile
path
-1 ;; 0 (false) = don't overwrite , -1 (true) = overwrite
0 ;; 0 (false) = ascii, -1 (true) = unicode
(setq file (vlax-invoke fso 'GetFile path))
( (setq file (vlax-invoke fso 'GetFile path))
(setq stream
(vlax-invoke
file
'OpenAsTextStream
8 ;; 1 = read, 2 = write, 8 = append
0 ;; 0 = ascii, -1 = unicode, -2 system default
(vlax-invoke stream 'Write text)
(setq result (vlax-get file 'Size))
result
(defun _ToMap ( i map )
;; 2016 Michael Puckett
;; Note: map must be a sorted sequence of ascii codes
;; of a length equal to 2^n, where n can be 1-7
( (lambda ( mask shift / result )
(while (not (zerop i))
(setq
result (cons (nth (logand mask i) map) result)
i (lsh i shift)
(vl-list->string result)
(1- (length map))
(- (fix (/ (log (length map)) (log 2))))
(defun _FromMap ( x map )
( (lambda ( x map shift result )
(while x
(setq result (+ result (length (member (car x) map))))
(if (setq x (cdr x)) (setq result (lsh result shift)))
result
(mapcar 'chr (vl-string->list x))
(mapcar 'chr (reverse (cdr map)))
0
(defun _IntToOct ( i )
;; Convert integer to octal.
(atoi (_ToMap i '(48 49 50 51 52 53 54 55)))
(defun _OctToInt ( x )
;; Convert octal to integer.
(_FromMap
(if (eq 'int (type x)) (itoa x) x)
(defun _EncA ( )
;; Values lifted from GILESP's post (THANK YOU SIR!)
;; at theswamp.org (see tinyurl.com/j8bojly):
'( 000 001 002 003 004 005 006 007 010 011 012 013 014 015 016
017 020 021 022 023 024 025 026 027 030 031 032 033 034 035
036 037 040 041 042 043 044 045 046 047 050 051 052 053 054
055 056 057 060 061 062 063 064 065 066 067 070 071 072 073
074 075 076 077 100 101 102 103 104 105 106 107 110 111 112
113 114 115 116 117 120 121 122 123 124 125 126 127 130 131
132 133 134 135 136 137 140 141 142 143 144 145 146 147 150
151 152 153 154 155 156 157 160 161 162 163 164 165 166 167
170 171 172 173 174 175 176 177 200 201 202 203 204 205 206
207 210 211 212 213 214 215 216 217 220 221 222 223 224 225
226 227 230 231 232 233 234 235 236 237 240 241 242 243 244
245 246 247 250 251 252 253 254 255 256 257 260 261 262 263
264 265 266 267 270 271 272 273 274 275 276 277 300 301 302
303 304 305 306 307 310 311 312 313 314 315 316 317 320 321
322 323 324 325 326 327 330 331 332 333 334 335 336 337 340
341 342 343 344 345 346 347 350 351 352 353 354 355 356 357
360 361 362 363 364 365 366 367 370 371 372 373 374 375 376
377
(defun _DecA ( )
'( 214 213 216 215 210 207 212 211 204 203 206 205 200 177 202
201 174 173 176 175 170 167 172 171 164 163 166 165 160 157
162 161 254 253 256 255 250 247 252 251 244 243 246 245 240
237 242 241 234 233 236 235 230 227 232 231 224 223 226 225
220 217 222 221 314 313 316 315 310 307 312 311 304 303 306
305 300 277 302 301 274 273 276 275 270 267 272 271 264 263
266 265 260 257 262 261 354 353 356 355 350 347 352 351 344
343 346 345 340 337 342 341 334 333 336 335 330 327 332 331
324 323 326 325 320 317 322 321 014 013 016 015 010 007 012
011 004 003 006 005 000 377 002 001 374 373 376 375 370 367
372 371 364 363 366 365 360 357 362 361 054 053 056 055 050
047 052 051 044 043 046 045 040 037 042 041 034 033 036 035
030 027 032 031 024 023 026 025 020 017 022 021 114 113 116
115 110 107 112 111 104 103 106 105 100 077 102 101 074 073
076 075 070 067 072 071 064 063 066 065 060 057 062 061 154
153 156 155 150 147 152 151 144 143 146 145 140 137 142 141
134 133 136 135 130 127 132 131 124 123 126 125 120 117 122
121
(defun _XMLtoDST ( stream )
;; Convert an XML stream to a DST (drawing Sheet Set) stream.
;; Algorythm translated from GILESP's vbscript post (thank you
;; sir!) at theswamp.org (see tinyurl.com/j8bojly). Also big
;; thanks to Jeff H and JAR at the swamp for their legwork that
;; made GILESP's vbscript possible.
(vl-list->string
(mapcar
(function
(lambda ( x )
(_OctToInt
(nth
(vl-position (_IntToOct x) (_DecA))
(_EncA)
(defun _DSTtoXML ( stream )
;; Convert a DST (drawing Sheet Set) stream to an XML stream.
(vl-list->string
(vl-remove 'nil
(mapcar
(function
(lambda ( x / result )
(if
(null
(member
(setq result (_OctToInt (nth x (_DecA))))
'(172 254)
result
(defun _DstFiletoXmlFile ( dstFileName xmlFileName / dstStream xmlStream bytesWritten )
;; Given an input dst (drawing sheet set) file name and a xml
;; output file name translate the dst to xml.
(and
(setq dstStream (_ReadStream dstFileName nil))
(setq xmlStream (_DSTtoXML dstStream))
(numberp (setq bytesWritten (_WriteStream xmlFileName xmlStream "w")))
(< 0 bytesWritten)
(defun _XmlFiletoDstFile ( xmlFileName dstFileName / xmlStream dstStream bytesWritten)
;; Given an input xml file name and an output dst (drawing
;; sheet set) output file name translate the xml to dst.
(and
(setq xmlStream (_ReadStream xmlFileName nil))
(setq dstStream (_XMLtoDST xmlStream))
(numberp (setq bytesWritten (_WriteStream dstFileName dstStream "w")))
(< 0 bytesWritten)
;; Typical use:
;; (setq
;; dstSource "x:\\SourceSheetSet.dst"
;; xmlTest "x:\\TestSetTest.xml"
;; dstTest "x:\\TestSetTest.dst"
;; (_DstFiletoXmlFile dstSource xmlTest)
;; Edit xmlTest to suit, then:
;; (_XmlFiletoDstFile xmlTest dstTest)
;; If dstTest proves ok use it to overwrite dstSource.
(princ)
I just know how to use LISP when there is a "c:" command line, but I do know how to use this lisp.
can someone tell me how to use this lisp?
PD:
according to the creator "MP"
this is the user guide, but I don't understand it:
;; Typical use:
;; (setq
